"error while loading shared libraries" error when running simpleFoam in parallel |
August 1, 2023, 15:19 |
Tim
I am putting together a cluster of 20 physical computers, each containing 4 cores. Right now I am trying to get the master and the first node (acl-n1) working. I am using MPI and NFS.
From my understanding, the openfoam9 dir should be in my shared folder OpenFOAM. I have updated the bashrc in openfoam9/etc/bashrc to correspond with the new dir. Some context info: $PATH /home/mpiuser/.local/bin:/path/to/openmpi/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam56/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/cmake-*/bin:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/bin:/home/mpiuser/OpenFOAM/openfoam9/wmake:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin $LD_LIBRARY_PATH /home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/paraview-5.6:/opt/paraviewopenfoam56/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/dummy Shared folder that is mounted correctly on acl-n1: /home/mpiuser/OpenFOAM $FOAM_INST_DIR=/home/mpiuser/OpenFOAM $FOAM_RUN=$FOAM_INST_DIR/mpiuser-9/run $machines is: master acl-n1 I copied the tutorials dir to $FOAM_RUN, and im trying to run the airFoil2D case: Code:
mpirun --hostfile $machines -np 5 simpleFoam >> log Code:
-------------------------------------------------------------------------- mpirun was unable to find the specified executable file, and therefore did not launch the job. This error was first reported for process rank 4; it may have occurred for other processes as well. NOTE: A common cause for this error is misspelling a mpirun command line parameter option (remember that mpirun interprets the first unrecognized command line token as the executable). Node: acl-n1 Executable: /home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam -------------------------------------------------------------------------- If I specify where simpleFoam is exactly: Code:
mpirun --hostfile $machines -np 5 $FOAM_INST_DIR/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam >> log Code:
/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam: error while loading shared libraries: libPstream.so: cannot open shared object file: No such file or directory -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[49322,1],4] Exit code: 127 -------------------------------------------------------------------------- Please help, I have been tearing out my hair for weeks on this!! |
mpi, nfs, openfoam9, parallel, shared libraries |
Issues Running in Parallel on SLURM HPC | jd01930 | OpenFOAM Running, Solving & CFD | 0 | November 30, 2022 17:12 |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 04:01 |
Identifying Markers in a CGNS Mesh | tjim | SU2 | 3 | October 12, 2018 01:21 |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
