[Sponsors] | |||||
Humberto
Rep Power: 6 ![]() |
Hello everyone. I'm facing an issue that seems simple but I can't find a solution for it.
I'm simulating a countercurrent flow of vapor/liquid, with vapor phase absorption. The solution is going well and doesn't cause divergence. However, when I add another phase (solid), it ends up causing divergence in the solution. What ends up happening is that the temperature becomes negative, I tried limiting it but it didn't work. Another thing is the increase in the Courant number, but even with the higher velocity within the solid spaces (due to porosity), using a low inlet velocity still causes the issue. The case seems quite similar to the trickle bed tutorial with some modifications. Case: 3 Phases - Solid, Liquid, Gas 1D multiphaseEulerFoam - OpenFoam v8 reaction Chemistry transfer mass between phases - CO2 to Liquid Boundary_Condiction: pressure: prghTotalPressure -Outlet ; fixedFluxPressure -Inlet Velocity / Composition (Y)/ Alpha / Temperature: fixedValue -inlet; zeroGradient -Outlet |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Initial conditions for solid granular phase in Eulerian multiphase flow | Bharath_vittal | Fluent Multiphase | 0 | May 24, 2022 11:42 |
| solid dispersed phase error using multiphaseEulerFoam | Ahyar | OpenFOAM Running, Solving & CFD | 0 | March 29, 2022 04:07 |
| Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model | Dingens | FLUENT | 0 | July 9, 2021 07:19 |
| What viscosity to use for solid phase in VOF model | redwanamit034 | FLUENT | 0 | June 14, 2017 18:09 |
| How to calculate density of solid phase | zhou | Main CFD Forum | 0 | December 17, 1999 20:06 |
