Looking for help creating separate rotating region for wind turbine
Old   September 22, 2023, 09:56
Default Looking for help creating separate rotating region for wind turbine
Niall O'Neill
nialloneill is on a distinguished road
Hello, I have been attempting to model a wind turbine which will involve a separate rotating region using AMI. However I have been struggling in the meshing process.
I can mesh the blades themselves no problem when the AMI region isn't considered but when I include the AMI .stl files in the SHM dictionary, it just meshes the AMI region (im guessing since the blades are inside in that region all of those cells are neglected after the catellation stage.)
I have been following a tutorial from CFD support which follows the same process (linked below) but they didn't seem to be having the same problem. My SHM dictionary seems to match theirs in terms of all the settings, while the stl files themselves obviously differ.
https://www.cfdsupport.com/openfoam-...t/node276.html
In that tutorial what seems to happen (for the rotating region) is that the blockMesh is created (an outside cube), then surfaceFeatureExtract is run, and then both the blades and the AMI region are defined in the SHM dict. The end result is just a mesh containing the AMI cylinder region and the blades, without the original block Mesh. Have been stuf on this for a while now. If anyone could help me with this that would be much appreciated. Thanks
nialloneill is offline   Reply With Quote
Rotating Region - Results EmmTheof84 FLUENT 1 November 21, 2020 15:53
splitMeshRegions 1D Wirman OpenFOAM Running, Solving & CFD 4 May 5, 2020 16:05
Adding turbulence intensity source in separate region Haeussti6 STAR-CCM+ 5 September 11, 2019 09:27
Fluent: Flow won't interact with rotating region TOlsen FLUENT 0 September 26, 2016 11:30
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 09:58
