December 31, 2023, 08:36 |
yPlus in OpenFOAM
Anurag
Rep Power: 3 |
Hi guys,
I am using k-epsilon turbulence model in interFOAM. Currently my yPlus values range from min:2 to max: 400 with an average of 10 and changes with time. Will the yPlus value become constant as the simulation reaches steady state? I am simulating flow in a pipe. So what should be my ideal yPlus value? is it around 30 for k-e model? Thanks. |
December 31, 2023, 16:38 |
ONESP-RO
Rep Power: 5 |
Assuming you're using the standard kEpsilon:
- You must use wall functions. - Your yPlus must be greater than 30 and less than say 200 (this is not hard limit). Usually, your yPlus should be around 50 or 60.
Don't keep making the same mistakes. Try to make new mistakes. |
January 4, 2024, 11:07 |
Anurag
Rep Power: 3 |
Hi , I am using the default ke model in Openfoam and the BCs defaultly available in 0 dir in OpenFOAM. Is this fine?
January 6, 2024, 12:33 |
Saeed Jamshidi
Rep Power: 7 |
Hi anubasu,
Let me add somthing to this thread. For the cases you are going to use k-epsilon turbulence model you should use wall functions in which y-pluse belongs to the logarithmic region, because k-epsilon turbulence model isn't accurate just near the wall due to some assumtions in order to evaluate this model constant numbers; Screenshot (241).png & Screenshot (240).png Besides, each tutorial has introduced delibrately in order to convey a message and purpuse. For example, I have seen motorbike case in both simpleFoam and pisoFoam. You can develope and use tutorials based on your requirement. However, the contents of the tutorials are correct. |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
