Boundary Conditions for Converging Pipe
Old   March 5, 2009, 09:09
Default I'm testing OpenFoam for a sim
Sami Lakka
sami_lakka is on a distinguished road
I'm testing OpenFoam for a simple pipe flow case which consists from inlet, sudden contraction and outlet. The flow is laminar and I use icoFoam-solver.
My B.C for U is fixedValue (1) for inlet and zeroGradient for outlet.
B.C for pressure is zeroGradient for inlet and fixedValue (0) for outlet.
I would expect the flow speed to increase in the contraction but it is the same as in the inlet. I'm probably making a stupid mistake with boundary conditions so could somebody point out my mistake so I can go and cry in the corner.
sami_lakka is offline   Reply With Quote
Old   March 5, 2009, 09:23
Default Your BCs seem correct. What ab
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Your BCs seem correct. What about the BC at the walls?
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   March 5, 2009, 09:36
Default Walls are fixed value 0 for U
Sami Lakka
Walls are fixed value 0 for U and zero gradient for p.
Here is the complete B.C definition (for U):
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.088419 0 0);
outlet
type zeroGradient;
beforeNozzle
type fixedValue;
value uniform (0 0 0);
afterNozzle
type fixedValue;
nozzle
type fixedValue;
frontAndBack
type empty;
And for p:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
beforeNozzle
type zeroGradient;
afterNozzle
type zeroGradient;
nozzle
type zeroGradient;
frontAndBack
type empty;
Old   March 5, 2009, 13:50
Default Could you post a picture of yo
santos's Avatar
Jose Luis Santos
Could you post a picture of your results? Its hard to figure out what could be wrong in your setup.
Regards,
Jose Santos
Old   March 6, 2009, 04:10
Default I managed to solve this. It wa
Sami Lakka
I managed to solve this. It was an error in my paraFoam visualization. I hadn't chosen a time step when I loaded the case. Instead I just pressed accept when paraFoam loaded. When I selected a time step using the slider the visualization shows correct values. Whatever the logic is behind this, I don't understand it.
Burgerbs equation non constant Boundary Conditions Initial Conditions arkangel OpenFOAM Running, Solving & CFD 1 October 2, 2008 14:48
Boundary Conditions for Stratified Pipe Flow Zhang FLUENT 0 June 30, 2008 13:33
periodic conditions, temperature not converging Husain CFX 3 April 29, 2007 19:21
Integral boundary conditions turbulent intensitylength boundary conditions olesen OpenFOAM Running, Solving & CFD 0 July 27, 2006 07:18
Pipe Flow Boundary conditions Kunal Jain Main CFD Forum 0 September 4, 2001 20:52
