Floating point exception
Old   February 16, 2009, 05:08
Default Hello, I'm trying to figure o
Gareth
gareth__it_power is on a distinguished road
I'm trying to figure out the reason for a floating point exception error being returned after 3 iterations in my lesInterFoam model. The model works with one particular inlet velocity, but blows up when that velocity is reduced. It's a 2d duct with an inlet of which half is air and half is water. There are two exits, the idea being the water falls out of the lower, and the upper exit being defined as atmosphere. For inlet velocity of 2m/s a good result is produced. If I reduce the velocity to 0.5m/s then it blows up.
I'd be very grateful for any advice please!
How do I post case files here?
Thanks
gareth
gareth__it_power is offline   Reply With Quote
Old   February 16, 2009, 08:31
Default Ah, here is my case file, just
Gareth
Ah, here is my case file, just in case anybody has time for a quick look!
Old   February 16, 2009, 12:55
Default Hi Gareth! The case isn't d
Assistant Moderator
Bernhard Gschaider
Hi Gareth!
The case isn't downloadable (at least for me) and as I don't have any deeper experience with either LES or interFoam I wouldn't want to comment on it. But try compiling a debug-version (http://openfoamwiki.net/index.php/HowTo_debugging) and the output of that might help you to find the problem
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Floating point exception? Ricky Wong FLUENT 19 March 28, 2020 15:32
Floating Point Exception?? Alex FLUENT 2 April 21, 2009 01:29
floating point exception mojtaba FLUENT 4 November 16, 2008 04:23
floating point exception mojtaba CFX 2 November 15, 2008 06:58
floating point exception Mojtaba CFX 0 November 1, 2008 01:54
