Z direction thickness control when using fluentMeshToFoam to extrude 2D mesh
Like Tree2Likes
  • 2 Post By juho
Old   January 31, 2009, 13:52
Default Hi, all I'm using the fluen
wei wu
wei_wu is on a distinguished road
Hi, all
I'm using the fluentMeshToFoam to extrude the 2D fluent mesh into 3D foam mesh. The aspect ratio is way too high for the boundary layer cells. I think the high aspect ratio comes from the Z dimension because when I check the 2D mesh in the gambit they are fine, but when I used the checkMesh after it's converted into 3D it reported the high ratio problem. I'm using 0.0001m for the thickness of first the boundary layer cell , but the thickness in the Z direction is 1.442m, which is automatically generated after fluentMeshToFoam. My question is how can I control the Z direction dimension when I'm converting the 2D mesh to a 3D?
Thank you
wei_wu is offline   Reply With Quote
Old   February 1, 2009, 03:43
Default Hello, The quick alternative
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
The quick alternative can be you shall extrude the mesh in GAMBIT for a small z distance and export it to OPENFOAM. Since OpenFoam works with 3d geometry, may be the default size is set as some specific number.. If you have time for it you shall fix it...
may be it helps you...
maruthamuthu_venkatraman is offline   Reply With Quote
Old   February 1, 2009, 04:15
Default I think you could use transfor
Juho Peltola
juho is on a distinguished road
I think you could use transformPoints to change the Z-thickness after the extrusion. For example scale (1 1 0.1) would result in Z-thickness of 0.1442m on your mesh.
Saideep and zp_chem like this.
juho is offline   Reply With Quote
Z direction thickness control by using fluentMeshToFoam wei_wu OpenFOAM Running, Solving & CFD 0 January 31, 2009 13:51
extrude 2D mesh stefan CFX 1 June 8, 2008 21:41
thermal conductivity in plane &thickness direction sreenivas Siemens 1 February 21, 2008 05:27
Extrude mesh in ICEM CFD Susan CFX 2 November 5, 2007 17:10
How to extrude 2D Mesh in ICEM CFD? VSB CFX 7 December 27, 2006 11:58
