LRR turbulence model
Old   January 23, 2009, 13:53
Default Hi Foamers, I've a problem
Gian Gianni
gianlu is on a distinguished road
Hi Foamers,
I've a problem when running a turbulence simulation using a LRR model (simpleFoam solvers for a steady state 2D problem). After few time steps the time step continuity error grows up and the number of iteration for the pressure grows too. The problem is the 'classical' turbulence test case: a backward facing step flow at high reynolds number (300000 based on inlet height). I tried to inizialize the solution using a solution after 100 time step of k-e model (that converge correctly), but the problem still remain. The problem is on the pressure. I used a DIC scheme for pressure. The mesh is a simple mesh generated with blockMesh.
For the boundary conditions I used the notorious relations for k and epsilon at the inlet. At the wall, for according with wall functions, I used zerogradient. I inizialized R with the built-in utility in OpenFoam for the 100th time step.
Thanks a lot
gianlu is offline   Reply With Quote
Old   July 25, 2009, 11:27
Default Hey!!! Similar problem here!!
Barath Ezhilan
barath.ezhilan is on a distinguished road
Hey. I am facing a similar problem here. Did you by any chance, find a solution, tat made your problem work,
Regards,
Barath.
barath.ezhilan is offline   Reply With Quote
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 12:12
turbulence model greg FLUENT 3 August 26, 2006 11:07
v2-f model of turbulence abdellah FLUENT 2 February 27, 2005 00:49
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? Mirek Kabacinski FLUENT 5 August 24, 2003 22:31
k-w turbulence model allan Main CFD Forum 4 February 20, 2002 13:05
