Moving mesh part 2
Old   March 28, 2008, 11:57
Default Just to close the issue I brou
  #41
Kevin Smith
kev4573 is on a distinguished road
Just to close the issue I brought up a few posts ago - turns out I made a mistake somewhere along the way and I have it working now in parallel. I simply went back through the process of grid generation, case setup, etc and got it to work.
kev4573 is offline   Reply With Quote
Old   October 8, 2008, 09:53
Default dear all, i am a new user o
  #42
klaus drohme
docci is on a distinguished road
dear all,
i am a new user of OF-1.5 and have a problem with moveMesh; i tried to move two points of a cuboid along the edges such that the cuboid becomes a wedge. actually it is a small moving patch not only two points.
unfortunately the site/patch of the cuboit which inclines doesn´t stay planar.(patch type slip)
i tried many different options of the moveMesh untility and always the inclining patch deforms... anyone an idea?
docci is offline   Reply With Quote
Old   November 1, 2008, 10:43
Default I am currently use OpenFOAM1.5
  #43
Peter Lian
peter73 is on a distinguished road
I am currently use OpenFOAM1.5 and try to simulate an oscillating airfoil. My first step is to simulate a square moving with constant velocity [1 1 0].
I made some changes based on the example from the tutorial. However, I can only specify the x-velocity in the pointMotionUx and cellMotionUx.
I try to change the class from pointScalarField to pointVectorField, but the code does not recognize the definition.
The questions are:
1: How should a velocity [1 1 0] be specified?
2: what are the functions of pointMotionUx and cellMotionUx.
Thanks.
Peter
peter73 is offline   Reply With Quote
Old   November 12, 2008, 16:03
Default Hi Peter, 1. change dynamic
  #44
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hi Peter,
1. change dynamicMeshDict definition to "solver velocityLaplacian;" and rename *MotionUx to *MotionU changing their content to vectors
2. fixedValue, timeVaryingFixedValue, slip, symmetry, (I have not yet been able to get oscillatingFixedValue to work with OF 1.5)
have a good afternoon,
-Louis
louisgag is offline   Reply With Quote
Old   November 12, 2008, 16:26
Default Thanks, Louis. I am able to
  #45
Peter Lian
Thanks, Louis.
I am able to run the fixedValue. Just like you, the oscillatingFixedValue does not work with OF1.5. From a post under other thread it seems that bc work with OF1.4-dev. The warning message indicates that it is not implemented in OF1.5.
With OF1.4, the file is located in
src/OpenFOAM/fields/pointPatchFields/derived
now it is at
src/finiteVolume/fields/fvPatchFields/derived/
Humm... ???
Peter
Old   November 12, 2008, 16:55
Default Hi again Peter, I suppose y
  #46
louisgag's Avatar
Louis Gagnon
Hi again Peter,
I suppose you could always define the almost exact same condition as oscillatinFixedValue using a timeVaryingFixedValue condition (especially if you are working with a constant timestep) by using a home-made piece of code to generate the "*.dat" file that defines the mesh motion.
-Louis
Old   November 12, 2008, 17:26
Default Louis, Thanks again. It w
  #47
Peter Lian
Louis,
Thanks again. It works. I also find this link discussing the unsteady bc. http://albertopassalacqua.com/?p=69#comment-209
Still do not understand why the oscillatingFixedValue does not work. It is under the same directory.
Peter
Old   February 25, 2010, 16:11
rubenparedes's Avatar
Ruben Paredes
rubenparedes is on a distinguished road
Send a message via MSN to rubenparedes
Hi there,
I am new to OpenFOAM and I am trying to simulate an oscillating cylinder. Only in the case that someone is looking for another option to simulate oscillating motion. I specified my moving BC as oscillatingVelocity type in the pointMotionU file.
Ruben
rubenparedes is offline   Reply With Quote
Old   December 3, 2010, 17:13
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
It seems to be a bug, during RBF interpolating, the LUdecompose met a singular matrix.
The RBF works good for serial, but the parallel run fails. Could anyone helps me on this?
Later I found in file "RBFMotionSolver.C", line
    Info << "Total points on moving boundaries: " << nMarkedPoints << endl;
    Info << "Total points on static boundaries: " << nMarkedPoints << endl;
    Info << "Number of internal points: " << nMarkedPoints << endl;
It seem it just outputs one processor's number, could it be possible to output the whole information?
And how to do LUdecompose on the whole mesh points, not just one processor?
Thanks,
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   December 14, 2010, 06:20
Daniele
Daniele111 is on a distinguished road
hi
Can (and How) I use update.mesh to modify a patch of a mesh? I have a rectangular box, and I would update bottom with a new shape, Can I do to solve this problem?
Thanks
Daniele111 is offline   Reply With Quote
Dynamic Mesh tutorial Part I attachDetach hsieh OpenFOAM Running, Solving & CFD 5 October 11, 2012 15:00
Can we add extra solid mesh part to the analsis? Farhath Alam FLUENT 0 December 22, 2006 02:41
Designating a part of mesh as wall megan FLUENT 0 October 15, 2006 21:04
Problem with rotational mesh deformation: Part II NymphadoraTonks CFX 2 November 4, 2004 03:05
Moving part in a fluid E. BOINOT FLUENT 0 April 24, 2002 09:34
