Help using dynamicInkjetFvMesh
Old   October 14, 2008, 15:11
Default Did you ever figure out what t
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Did you ever figure out what the proper usage for dynamicInkJetFvMesh actually was? I am curious as to how this works as well since I would like to handle 3d pulsing multiphase flow. Anyone? Any help is much appreciated.
chegdan is offline   Reply With Quote
Old   October 29, 2008, 18:06
Default Anush, can you move the dynam
MR Amiralaei
reza is on a distinguished road
Anush,
can you move the dynamic mesh by this dynamicmesh dict?
did you use any other file to get the case running?
I applied your dict but the error came out. At this stage I am examining how to use it. Can you plz share it if you have been successful.
P. S. In the source file of ink jet it seems that your dict is enough but does not work
reza is offline   Reply With Quote
Old   October 29, 2008, 18:42
Default Soory I should post the error
MR Amiralaei
Soory I should post the error here, when trying to run moveDymaicMesh:
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicInkJetFvMesh
word::stripInvalid() called for string constantregion0
Aborted
P. S. I saw the posts related and the problem was the invalid character or unnessecary spacing between strings, but here what is the problem?
Using dynamicInkJetFvMesh treadstone OpenFOAM Running, Solving & CFD 0 December 3, 2008 04:47
