October 14, 2008, 15:11 |
Did you ever figure out what t
Daniel P. Combest
Did you ever figure out what the proper usage for dynamicInkJetFvMesh actually was? I am curious as to how this works as well since I would like to handle 3d pulsing multiphase flow. Anyone? Any help is much appreciated.
October 29, 2008, 18:06 |
Anush,
can you move the dynam
MR Amiralaei
Anush,
can you move the dynamic mesh by this dynamicmesh dict? did you use any other file to get the case running? I applied your dict but the error came out. At this stage I am examining how to use it. Can you plz share it if you have been successful. P. S. In the source file of ink jet it seems that your dict is enough but does not work |
October 29, 2008, 18:42 |
Soory I should post the error
MR Amiralaei
Soory I should post the error here, when trying to run moveDymaicMesh:
Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicInkJetFvMesh word::stripInvalid() called for string constantregion0 Aborted P. S. I saw the posts related and the problem was the invalid character or unnessecary spacing between strings, but here what is the problem? |
Using dynamicInkJetFvMesh | treadstone | OpenFOAM Running, Solving & CFD | 0 | December 3, 2008 04:47 |
