Announcement for an discrete element code for foam
Like Tree1Likes
Old   February 16, 2007, 08:53
Default hi all, in two or three wee
Stephan Gerber
stephan is on a distinguished road
hi all,
in two or three weeks i will set a link for a dem-code based on liblagrangian ( i have to clean up the code first).
the code uses the spring-damper-model from tsuji and will therefore be easy to extend to other collisionmodels.
it allows collsions between more than two particles at the same time and uses a cell-linking algorithm to achieve better perfomance. it could be interesting for people doing mol. dynamics or dense particle-flows.
anybody interested?
stephan
m9819348 likes this.
stephan is offline   Reply With Quote
Old   February 16, 2007, 10:57
Default Hi Stephan, This sounds inte
Rasmus Hemph
hemph is on a distinguished road
Hi Stephan,
This sounds interesting! I have done a bit of DEM-simulations using OpenFOAM. I would be happy to see how you have implemented the algorithm and perhaps share some experience I gained in my project.
//Rasmus Hemph
hemph is offline   Reply With Quote
Old   February 16, 2007, 11:01
Default i would be very interested in
Anthony Costa
coastal593 is on a distinguished road
i would be very interested in working with this. i look forward to your release ...
ac;
coastal593 is offline   Reply With Quote
Old   March 16, 2007, 09:23
Default hi, since i have almost no
Stephan Gerber
hi,
since i have almost no time rightnow it will take some weeks more - but here 3 pics from a simulation (kuipers, jie li " Gas-particle interactions in dense gas-fluidized beds" -2003)
first the situation just after the start and two pics after some seconds.
(gas flows come from the whole base plate)
the point on these pics is that there is no overlapping.
Stephan
Old   June 28, 2007, 10:42
Default any luck with this? still very
Anthony Costa
any luck with this? still very interested.
Old   June 29, 2007, 08:51
Default hi, sorry that the source s
Stephan Gerber
hi,
sorry that the source still isnt there - i am still havent clean up the source -about 60% of the works is done. the source will be online in two weeks - i promise!
i am just pretty busy - i started my pdh and was busy finding somebody how wants to pay for this phd-project....
greetings
stephan
Old   July 15, 2007, 11:57
Default hi, i made it finally to pa
Stephan Gerber
hi,
i made it finally to pack a version of my DEM application.
If anybody wants a copy, write me an email and i will send you a copy.
greetings
stephan
Old   July 16, 2007, 07:50
Default Dear Stephan, I am interest
Pei-Ying Hsieh
hsieh is on a distinguished road
Dear Stephan,
I am interested. Could you please send me a copy? Thanks!
phsieh2005@yahoo.com
hsieh is offline   Reply With Quote
Old   July 21, 2007, 14:09
Default hi, in case some of the foa
Stephan Gerber
hi,
in case some of the foamers which got the source from the dem are actually using the code:
you should double the depth of the bed in blockMeshDict from 0.002 to 0.004 (the size of the particles) and higher the inlet velocity a bit.
sorry for the messed up case-dir..
greeting
stephan
Old   July 22, 2007, 16:20
Default hi, i hope everybody who wa
Stephan Gerber
hi,
i hope everybody who wanted the sources got them. if not just write an email.
greetings
stephan
Old   July 22, 2007, 22:04
  #11
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Dear Stephan,
I am interested. Could you please send me a copy? Many thanks!
sujunwei@gmail.com
su_junwei is offline   Reply With Quote
Old   July 23, 2007, 00:52
Default Stephan, could you send me a c
  #12
Ruben I. Mukhamadeev
benru is on a distinguished road
Stephan, could you send me a copy of sources ?
Best regards,
Ruben
benru is offline   Reply With Quote
Old   July 23, 2007, 11:28
Default hi, i had some trouble writ
  #13
Stephan Gerber
hi,
i had some trouble writing a mail to Sreekanth Pannala - no matter if i attach something or not the mail comes back with an failure notice, which includes the information that the mail couldnt be delivered.
greetings
stephan
Old   July 23, 2007, 12:00
Default hi there, Could you send me
  #14
Anthony Costa
hi there,
Could you send me a copy? I emailed you a bit ago but perhaps I got the wrong address. My email is abcosta@purdue.edu
Thanks
Anthony
Old   July 28, 2007, 12:29
Default Dear Stephan, Could you plea
  #15
cfdfans
Dear Stephan,
Old   July 28, 2007, 14:21
Default Dear Stephan, Could you pleas
  #16
roy fokker
dbxmcf is on a distinguished road
Dear Stephan,
Could you please send me a copy to fchen3@utk.edu? Thanks!
dbxmcf is offline   Reply With Quote
Old   July 29, 2007, 16:14
Default Hi, Stephan, I still have n
  #17
Pei-Ying Hsieh
Hi, Stephan,
I still have not gotten the code yet. Could you please send it again? Thanks!
Pei
peiying2006@gmail.com
Old   July 30, 2007, 12:40
Default Hi, Stephan, I`m intereste
  #18
Alexander Rudert
alexanderrudert is on a distinguished road
Hi, Stephan,
I`m interested too. Could you please send me a copy?
alexander.rudert@imfd.tu-freiberg.de
Thanks Alex
alexanderrudert is offline   Reply With Quote
Old   July 30, 2007, 17:27
Default hi, after sending sources t
  #19
Stephan Gerber
hi,
after sending sources to about 20 people i guess that it will be much more efficient to put it on the wiki....
since i am quite busy right now this will happen in the end of september.
greetings
stephan
Old   August 4, 2007, 22:33
Default is your code coupled? how did
  #20
D.Y.Xu
dyxu is on a distinguished road
is your code coupled? how did you implement it?
dyxu is offline   Reply With Quote
IcoTopo mixerMeshslide Foam Code pilot OpenFOAM Running, Solving & CFD 6 September 19, 2006 13:31
code for finite element Jerry Main CFD Forum 0 March 17, 2004 22:07
anyone doing discrete element + fluid? George Bergantz Main CFD Forum 0 September 28, 2002 01:33
Discrete element method? Ki Ha Hong Main CFD Forum 1 May 28, 1999 09:46
