Snappyhexmesh and solid body motion
Old   October 23, 2008, 15:20
Default Dear all, I would like to use
erik023
Dear all,
I would like to use snappyhexmesh to mesh the hull of a boat in a blockmesh background mesh and then, using interfoam/interdymfoam work out how the boat reacts (rising, falling, moving due to the water). i have manage to get the boat in there and to fill the domain with some water and by adding a velocity at an inlet i work out that the flow around the boat looks resonable. though i have not worked out how to get the boat to move when the water is flowing at it. i tried the 3d3dof tutorial but then my boat stays put and the blockmesh domain is moving. also it does not seems right that i specify the parameters, they should be calculated from the flow. did anyone do something similar?
how can i specify that the beat should be moving with 2 och 3 dof?
would be happy for any input.
thanks
Erik
Old   October 24, 2008, 04:53
Default just to make it clearer i here
erik023
just to make it clearer i here add the right terms: i like to ship to react by heaving (moving up/down) and pitching (tilting backward/forward).
thanks
Erik
simple rigid body motion UDF Dan FLUENT 0 January 11, 2006 05:48
Dynamic meshing: UDF for rigid body Motion Manoj Kumar FLUENT 0 June 20, 2005 01:02
Define the motion of rigid-body CG using profiles! ducvinh FLUENT 2 October 2, 2004 02:50
rigid body motion antonello FLUENT 3 July 28, 2004 03:25
Rigid Body Motion in Eulerian Grid Zi-Wei Chiou Main CFD Forum 0 November 14, 2001 22:39
