May 1, 2007, 20:20 |
Hi Eugene:
A quick question
#21 |
Ning Yang
Rep Power: 17 |
Hi Eugene:
A quick question: what does "pressure gradient" in log file stand for? Is it the streamwise pressure gradient after each step? If this is the case, it should be negative for channelOodles. For my case, Retau = 180. Channel dimension is pi*1*pi/2. No matter which perturbU code I used, pressure gradient always converged to a certain value between 1 and 2. Did I misunderstood something? Ning |
May 2, 2007, 06:12 |
gradp is the magnitude of the
#22 |
Eugene de Villiers
Rep Power: 21 |
gradp is the magnitude of the externally applied pressure gradient needed to maintain Ubar.
It is applied to the momentum equation as: == flowDirection*gradp Check channelOodles.C for details. Certainly, its sign has no bearing on perturbU, which only sets initial conditions. |
May 2, 2007, 20:13 |
Thanks Euqene for providing th
#23 |
lijian sun
Rep Power: 17 |
Thanks Euqene for providing the new version of pertubU, I am testing it now!
Ning, I think you get the meaning for gradP now from Euqene. For my case, the pressure gradient is about (1.21e-5), and the normalized value is 1.8. I think it is in the reasonable range. |
May 2, 2007, 20:42 |
Somehow I still can't get pres
#24 |
Ning Yang
Rep Power: 17 |
Somehow I still can't get pressure gradient right. Anyhow, thank you for letting me know.
Eugene: thank you for your explanation. It is now pretty clear to me. Ning |
May 5, 2007, 02:53 |
Hi Ning and Rex
What is yo
#25 |
Marhamat Zeinali
Rep Power: 17 |
Hi Ning and Rex
What is your idea about new version of perurbU? Did you see turbulance structures in your case after running? Best Regards Marhamat |
May 8, 2007, 07:20 |
Hello Eugene
For initializati
#26 |
Marhamat Zeinali
Rep Power: 17 |
Hello Eugene
For initialization of LES cases we are testing a new method. You can see application of this method for turbulent flat plate in http://www.cfd-online.com/OpenFOAM_D...tml?1178524227 what is your idea after a first general view ? Best Regards Marhamt |
May 8, 2007, 08:28 |
Are you seriously trying to ru
#27 |
Eugene de Villiers
Rep Power: 21 |
Are you seriously trying to run a LES flat plate in 2D?
May 8, 2007, 09:02 |
I'm trying LES flat plate in 2
#28 |
Marhamat Zeinali
Rep Power: 17 |
I'm trying LES flat plate in 2D only for time serving.So i don't sure in 2D simulation of this case.
Thanks alot Marhamat |
May 9, 2007, 17:04 |
Hello Eugene
Can i expect goo
#29 |
Marhamat Zeinali
Rep Power: 17 |
Hello Eugene
Can i expect good result from 2D simulation of LES flat plate? In oodles step flow simulated in 2D. Best Regards Marhamat |
May 10, 2007, 05:36 |
No, 2D LES generally has no me
#30 |
Eugene de Villiers
Rep Power: 21 |
No, 2D LES generally has no meaning and certainly wont work for channel flows. If it is done for a tutorial case, then it is simply a demonstration of model and solver settings.
Unless you have a prominent turbulence production mechanism like a free shear layer or shedding, 2D LES wont produce any resolved motion at all. |
May 21, 2007, 02:54 |
Hi Eugene
I tried on 3D LES
#31 |
Marhamat Zeinali
Rep Power: 17 |
Hi Eugene
I tried on 3D LES cases by noted code(Tuesday, May 08, 2007 - 05:20 am) but i didn't see turbulent structures in 3D turbulent flat plate. I add that in duct flow i got good result by that. I'm compeletly wondering. Essentially what is the difference between these cases? What is your idea? Best Regards Marhamat |
July 9, 2007, 03:36 |
Hi to all,
I am simulating
#32 |
hadi tartoussi
Rep Power: 17 |
Hi to all,
I am simulating a LES turbulent channelflow using channelOodles, i fixed the value of Ubar and i ran the case for few iterations, i would like to get the values of u_tau in order to estimate the corresponding Re_tau. Does openFoam print out these values? u_tau=(nu*(du_x/dy+du_z/dy))^0.5 Thanks in advance hadi |
July 17, 2007, 04:10 |
Can u please answer
#33 |
hadi tartoussi
Rep Power: 17 |
Can u please answer my question posted above? I also tried to extract wallShearStress but i got the following message error : "keyword turbulenceModel is undefined in dictionary". Can anyone tell me how to get a converged value of U_tau? Cheers Hadi |
August 9, 2007, 04:45 |
Hi to all,
I ran a LES channe
#34 |
hadi tartoussi
Rep Power: 17 |
Hi to all,
I ran a LES channel flow simulation using channelOodles , and after 40 flows through time the mean fields are not symmetric. Could u please tell me what might be wrong in my simulation? dimensions 3.2x1x1.2 mesh:64x64x64 Ubar=1 Re_tau=180 y+=1 Uinitial Umean R |
August 9, 2007, 04:59 |
Nothing wrong here, as far as
#35 |
Hrvoje Jasak
Rep Power: 33 |
Nothing wrong here, as far as I can tell: either do averaging across homogenous planes (in z-direction?) or keep running.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
August 9, 2007, 05:19 |
Thank you so much for your rep
#36 |
hadi tartoussi
Rep Power: 17 |
Thank you so much for your reply!
I will keep running the simulation. Over how many flows through time should i run the simulation, to get the right mean fields? (i checked the velocity profile is good, rms of u, v and w did not converge yet) cheers Hadi |
August 9, 2007, 07:45 |
We recently had to run such a
#37 |
Eugene de Villiers
Rep Power: 21 |
We recently had to run such a case and it took around 200 flow-through times to converge the mean profiles. Normally a figure of around 100 is quoted in literature.
Making the duct longer can reduce the overall cost a bit since you have less artificial periodicity. |
August 10, 2007, 04:01 |
Thank you Eugene for your repl
#38 |
hadi tartoussi
Rep Power: 17 |
Thank you Eugene for your reply, hopefully i will get good results at the end.
Actually i am new to LES and openFOAM, but i found that it is important to calculate u_tau, when u fix U_bar, me i calculate u_tau=(nu*(du_x/dy+du_z/dy))^0.5 by modifying wallGradU utility without doing time average, but i dont know if it is the right way to do it.(does openFoam calculate this value?) My concern is when u simulate a new case that does not exist in literature, do you run the simulation to get a converged value of u_tau, and then u change the mesh with the adequate y+? (Sorry if my question seems a bit stupid or unclear) Thanks in advance Cheers Hadi |
August 10, 2007, 05:46 |
You should not use u_tau=(nu*(
#39 |
Eugene de Villiers
Rep Power: 21 |
You should not use u_tau=(nu*(du_x/dy+du_z/dy))^0.5 to calculate utau since this will only be accurate if your y+ < ~2. channelOodles provides you with a driving pressure gradient. Since wall shear is the only force balancing this gradient it is simple to compute utau from the pressure gradient. Thus if you want a fixed utau, it is better to prescribe a fixed pressure gradient than to adjust Ubar for instance.
August 10, 2007, 06:09 |
Thank you eugene for your answ
#40 |
hadi tartoussi
Rep Power: 17 |
Thank you eugene for your answer, actually in my case y+=1.
I know that i can calculate utau using : U_tau=[(gradp/rho)*2delta]^0.5 But i thought it is only valid for DNS. Is it the right way to do it? Cheers Hadi |
Burgerbs equation non constant Boundary Conditions Initial Conditions | arkangel | OpenFOAM Running, Solving & CFD | 1 | October 2, 2008 14:48 |
Initial conditions | Shuo | Main CFD Forum | 2 | July 27, 2007 08:57 |
Initial conditions = final conditions | Chucho | CFX | 5 | December 16, 2005 17:14 |
Initial conditions | Allan | CFX | 5 | April 23, 2002 08:54 |
Initial conditions in CFX 5.5 | Astrid | CFX | 3 | December 18, 2001 23:24 |
