Philippose Rajan
Rep Power: 25 ![]() |
Hello there,
A wonderful day to everyone... I hope everyone is experiencing the same weather that I have here :-)! Its brilliant! I have a quick question..... are there already any, or would anyone be good enough to provide me with some basic examples in which the Ordinary Differential Equation solvers available in OpenFOAM have been applied? Basically, I am considering using it as the solver for solution of rigid body motion (for those who know... just trying to make "turbForceFoam" more general, and elegant). Currently I solve only 1-D motion, and I solve it internally using the Euler numerical integration. In order to make it more general and consistent, I want to use the capabilities already available in OpenFOAM. (I use both OpenFOAM 1.4, and OpenFOAM 1.3 (dev version HRV_01_05_2007).... so examples in any one of them would be ok.) Have a nice weekend! Philippose |
Alberto Passalacqua
Rep Power: 36 ![]() ![]() |
Hello!
You can find an example among the tests provided with OpenFOAM: OpenFOAM-1.4/applications/test/ODETest The ODE solver is also used in applications like reactingFoam, which solves for chemical reactions. I hope this helps. Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. ![]() |
Philippose Rajan
Hey Alberto :-)
Thanks a lot... in fact... just after posting the message I remembered that the test folder should have something.... Yes... that definitely gives me a heads-up and a good start to the ODE solvers.... Hope I can implement something meaningful over the next few days! Philippose |
Bernardo D Flores
Rep Power: 17 ![]() |
Hello there
Does anyone knows how to integrate the ODE on OpenFOAM, i.e., using a solver like icoFoam and a ODE system serving as input on icoFOAM inlets to be solved at each time step. Any pointers are greatly appreciated Regards |
Capabilities | christianhf | OpenFOAM Running, Solving & CFD | 19 | November 11, 2010 00:33 |
Switching to OpenFOAM Merits and capabilities | s195404 | OpenFOAM | 0 | December 11, 2007 22:17 |
Fluid Structure Interaction and OpenFOAM capabilities | paka | OpenFOAM Running, Solving & CFD | 1 | June 6, 2007 13:56 |
Capabilities | christianhf | OpenFOAM | 0 | February 28, 2007 09:02 |
Multiphase capabilities | amc | FLUENT | 1 | March 1, 2001 23:11 |
