Examples of the ODE capabilities in OpenFOAM
Old   June 23, 2007, 13:10
Default Hello there, A wonderful da
Philippose Rajan
philippose will become famous soon enough
Hello there,
A wonderful day to everyone... I hope everyone is experiencing the same weather that I have here :-)! Its brilliant!
I have a quick question..... are there already any, or would anyone be good enough to provide me with some basic examples in which the Ordinary Differential Equation solvers available in OpenFOAM have been applied?
Basically, I am considering using it as the solver for solution of rigid body motion (for those who know... just trying to make "turbForceFoam" more general, and elegant).
Currently I solve only 1-D motion, and I solve it internally using the Euler numerical integration. In order to make it more general and consistent, I want to use the capabilities already available in OpenFOAM.
(I use both OpenFOAM 1.4, and OpenFOAM 1.3 (dev version HRV_01_05_2007).... so examples in any one of them would be ok.)
Have a nice weekend!
Philippose
philippose is offline   Reply With Quote
Old   June 23, 2007, 14:09
Default Hello! You can find an exampl
Alberto Passalacqua
Hello!
You can find an example among the tests provided with OpenFOAM:
OpenFOAM-1.4/applications/test/ODETest
The ODE solver is also used in applications like reactingFoam, which solves for chemical reactions.
I hope this helps.
Alberto
Alberto Passalacqua
Old   June 23, 2007, 15:05
Default Hey Alberto :-) Thanks a lo
Philippose Rajan
Hey Alberto :-)
Thanks a lot... in fact... just after posting the message I remembered that the test folder should have something....
Yes... that definitely gives me a heads-up and a good start to the ODE solvers....
Hope I can implement something meaningful over the next few days!
Philippose
Old   February 19, 2008, 16:59
Default Hello there Does anyone kno
Bernardo D Flores
david_flo1 is on a distinguished road
Hello there
Does anyone knows how to integrate the ODE on OpenFOAM, i.e., using a solver like icoFoam and a ODE system serving as input on icoFOAM inlets to be solved at each time step.
Any pointers are greatly appreciated
Regards
david_flo1 is offline   Reply With Quote
Capabilities christianhf OpenFOAM Running, Solving & CFD 19 November 11, 2010 00:33
Switching to OpenFOAM Merits and capabilities s195404 OpenFOAM 0 December 11, 2007 22:17
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
Capabilities christianhf OpenFOAM 0 February 28, 2007 09:02
Multiphase capabilities amc FLUENT 1 March 1, 2001 23:11
