October 25, 2007, 13:46 |
Did I have to get LAm from som
Sung-Eun Kim
Did I have to get LAm from somehwere? When I type lamboot -v .. it says lamboot coomand not found.
October 25, 2007, 14:30 |
OpenFOAM now uses OpenMPI. Ple
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
OpenFOAM now uses OpenMPI. Please refer to the latest user guide for details. If you choose to use LAM, you will need to build it.
October 25, 2007, 17:36 |
It is well documented on pages
Gabriel Barroso
It is well documented on pages 62 and 63 of the user guide. decompose the domain using decomposePar <root> <case>. The decomposParDict you can take from the brake of a dam tutorial case. After that you can run on a multiple processor/core machine with the command
mpirun -np <numberofprocessors> <solver> <root> <case> -parallel > log & |
October 27, 2007, 06:25 |
Hello there. Does anyone know
Joseph Dawes
Hello there. Does anyone know how to implement parallel processing with the mpich2sub command in OpenFOAM? I tried it but it doesn't seem to work with the -parallel option.
Thanks |
February 8, 2008, 12:12 |
due to my openmpi probl
Fabian Braennstroem
Rep Power: 19 |
due to my openmpi problems I would like to try 'lam' for 1.4.1 version. Do I have to to recompile the whole OpenFoam src directory after I changed the WM_MPILIB variable? Maybe there is a chance to use the existing lam as well? Regards! Fabian |
February 9, 2008, 04:49 |
Hi Fabian,
which openMPI-Pr
Thomas Gallinger
Hi Fabian,
which openMPI-Problems do you have? I have used lam, mpich and now openmpi, and with openmpi I had nearly no problems. Also notice that lammpi is no longer developed and openmpi is the official follower - so maybe your problems will not vanish by using lam. For using lam: As far as I know you just have to reompile the Pstream library after changing the corresponding switch to lam. Regards, Thomas |
February 11, 2008, 09:47 |
Hi Thomas,
thanks for your
Fabian Braennstroem
Rep Power: 19 |
Hi Thomas,
thanks for your help. My openmpi-PBS system run call looks like: mpirun np 4 simpleFoam . E1_SEHR_SST -parallel > log It runs all 4 processes on one cpu; which happens due the missing hostfile, I think. But the other call: mpirun -hostfile $PBS_NODEFILE -np 4 simpleFoam . E1_SEHR_SST -parallel > log does not work at all...!? I actually do not have any idea anymore and have to wait for an answer of my administrator. In the meanwhile I wanted to try lam. By the way, how do I recompile the 'Pstream library'? Is it the whole src directory with the Allwmake call and the corresponding MPILIB switch or is there a shorter way? Would be nice, if you have an idea :-) Thanks! Fabian |
February 11, 2008, 12:22 |
Hi Fabian,
are you using th
Thomas Gallinger
Hi Fabian,
are you using the newest OF-version 1.4.1 together with a queuing system? If yes, try to get rid of -hostfile $PBS_NODEFILE in your call. Don't ask why, this worked with openmpi 1.2.1, but not with 1.2.3. Also at the end exchange > log with >& log, so you also stream the error output into your log file. As far as I remember you just have to change the WM_MPLIB-Switch under OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc in line 126 and if you type Allwmake in your src directory only the necessary libraries are rebuild. Thomas |
February 11, 2008, 12:25 |
me again...
The lam comp
Fabian Braennstroem
Rep Power: 19 |
me again... The lam compilation and pstream works on my local machine with no problem. Is it possible to clean the directory and copy the working openfoam from local machine to the cluster. I am afraid that some path settings could make trouble!? Fabian |
February 11, 2008, 13:00 |
Hi Thomas,
yes, the newest
Fabian Braennstroem
Rep Power: 19 |
Hi Thomas,
yes, the newest 1.4.1 with a pbs queuing system. I actually tried to get rid of the 'hostfile', but how does openfoam/openmpi then know, how to distribute the domains? As mentioned above, all processes run on one node!? The compilation on the cluster does not work due to disk quota problems :-(( Fabian |
February 11, 2008, 13:25 |
I think I found a hint on tis
#11 |
Thomas Gallinger
I think I found a hint on tis startup problem somewhere in google.
But as I said, I don' know. I think openmpi recognizes to be run within a queueing systems and is somewhat compatible to it - that's just a suggestion. But it works, distribution of all processes is fine, so just try - hop it works! Thomas |
February 13, 2008, 07:36 |
Hi Thomas,
now it works :-)
#12 |
Fabian Braennstroem
Rep Power: 19 |
Hi Thomas,
now it works :-) I had to recompile openmpi with the "--with-tm" Option and defining the pbs binary directory. Unfortunately, it did not work as hoped in the begining due to a compiling error with gcc (see: http://www.cfd-online.com/OpenFOAM_D...tml?1196851788 ) Thanks for your help! Fabian |
Trouble with parallel runs | cfdmarkus | OpenFOAM Running, Solving & CFD | 9 | February 27, 2009 03:59 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Data storage for parallel runs | nordborg | OpenFOAM Running, Solving & CFD | 1 | October 9, 2007 04:19 |
parallel runs | Andy F | CFX | 1 | March 5, 2006 16:32 |
Distributed parallel runs on ANSYS CFX 10 | Manoj Kumar | CFX | 4 | January 25, 2006 08:00 |
