Differences between 32bit and 64bit results
Prev Previous Post   Next Post Next
Old   November 8, 2007, 06:21
Default Hello, Quick question.... i
Philippose Rajan
philippose will become famous soon enough
Quick question.... is it normal to see large differences in simulation convergence, and significant differences in the results between a 32bit and 64bit run of the same case using simpleFoam??
The 64-bit simulation was run on an AMD X2 (but using only one processor), and the 32-bit version on an Intel Quad-Core (but with OpenFOAM compiled without the WM_64=on option... and again using one processor).
The 64-bit simulation has convergence values at around 760 iterations, which are comparable to those seen at around 1600 iterations on the 32-bit simulation
Moreover.. the results are disturbingly different.
I use the AMG solver for pressure, and the PBiCG for the other fields.
I am not 100% sure anymore if both the systems use the exact same version of OpenFOAM, though both use the OpenFOAM-1.4.1 release (one could be a development release from the Powerlab ftp).
Hoping for an explanation.....
Philippose
philippose is offline   Reply With Quote
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Fluent - Windows XP-Prof 32bit - 4 GB RAM Peter Specht FLUENT 5 February 14, 2006 12:05
Can Fluent 32bit version run using 64bit CPU? Danny FLUENT 3 August 16, 2005 09:04
32bit STAR on 64bit OS & CPU Jihwan Siemens 6 May 23, 2005 01:58
64bit Server to 32bit Client Saturn FLUENT 0 March 31, 2005 02:35
