Simple 2D airfoil Boudary Conditions
Old   March 26, 2007, 16:55
Default Hi- I'm trying to run a sim
Doug Hunsaker
doug is on a distinguished road
Hi-
I'm trying to run a simple potential flow scenario around a 2D airfoil. I have generated my own grid, and am currently trying to set up my boundary conditions. However, I'm new to OpenFOAM and don't understand all the options for BC. I'm getting an error that says:
request for volScalarField psi from objectRegistry region0 failed available objects of type volScalarField are
3
p
div(phi)
1|A(U)
Any direction would be helpful.
Thanks.
-doug
doug is offline   Reply With Quote
Old   March 26, 2007, 18:18
Default Alright. I got that problem fi
Doug Hunsaker
Alright. I got that problem fixed with the help of FoamX. Now I have a new question: How do I map two faces together to form an internal boundary? I have two different grids that mate, and need to be able to specify that they connect.
Thanks.
-doug
Old   March 26, 2007, 18:30
Default Have a look at the stitchMesh
Hrvoje Jasak
Have a look at the stitchMesh application - sounds just like what you need.
Hrv
Hrvoje Jasak
Old   November 9, 2009, 10:32
Vasu
milleniumrider is on a distinguished road
I'm new to OF as well and am trying out some tutorials.
I'm getting the same error with the t-junction, pimpleFoam tutorial.. Can you let me know how you sorted it out? Any input will be much appreciated.
Thank you,
Vasu
milleniumrider is offline   Reply With Quote
What boudary conditions should I use lakeat OpenFOAM Running, Solving & CFD 3 February 12, 2008 03:20
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Far field boudary conditions in FDM James Main CFD Forum 3 July 20, 2005 02:44
outflow boudary condition in SIMPLE algorithm dallybird Main CFD Forum 0 March 6, 2003 11:55
boudary conditions for flow past a sphere srijit goswami Main CFD Forum 3 January 27, 2001 07:28
