Moving mesh forces on patches and turbulence solver
Old   May 31, 2007, 09:38
Default Hello, I hope someone can g
jackdaniels83 is on a distinguished road
I hope someone can give me some hints on that:
I am new to OpenFOAM, C++ and Linux and i need a solver that solves forces on selected patches in y-direction, uses a turbulence model and provides moving mesh. Has one done something like that?
If not, what solvers do i have to combine to get it.
I need it for my final year project at the university, where i have to calculate hydraulic valves for a company that is supplier for the automobile industrie.
Any help is welcome, thanks!
Daniel
jackdaniels83 is offline   Reply With Quote
Old   May 31, 2007, 09:46
Default Hi Daniel, do you need movi
Tommaso Lucchini
lucchini is on a distinguished road
Hi Daniel,
do you need moving mesh with or without topological changes?
if you need only moving mesh without topological changes, you can combine icoDyMFoam with turbFoam and you will get what you need. Then you need to write a dynamicFvMesh class accounting for the mesh motion of your case.
bye
Tommaso
lucchini is offline   Reply With Quote
Old   May 31, 2007, 09:58
Default Thanks Tommaso, I don't nee
Thanks Tommaso,
I don't need topo changes, it is only a linear moving cock.
But what is about the forces? I need the forces resulting from the oil flow that appear in the moving direction on the cock.
Daniel
Old   May 31, 2007, 10:29
Default Have a look at : http://www.cf
Dominique Turmel
doum is on a distinguished road
Have a look at : http://www.cfd-online.com/OpenFOAM_D...es/1/3814.html
This should help you a lot!
Dominique
doum is offline   Reply With Quote
Turbulent compressible solver rhoTurbFoam with dynamic moving mesh eno OpenFOAM Running, Solving & CFD 4 December 12, 2011 03:38
Moving mesh problem with a FSI solver mathieu OpenFOAM Running, Solving & CFD 8 January 25, 2010 09:08
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 21:35
LES with moving mesh solver gtg627e OpenFOAM Running, Solving & CFD 2 July 23, 2007 10:40
First steps w moving mesh FOAM FATAL ERROR solver table is empty tehache OpenFOAM Running, Solving & CFD 2 May 14, 2007 04:59
