First steps w moving mesh FOAM FATAL ERROR solver table is empty
Old   May 14, 2007, 04:41
Default Hi everybody, I am currentl
Thomas Jung
tehache is on a distinguished road
Hi everybody,
I am currently doing my first unsecure steps with a moving grid, starting my program I get this:
Selecting motion solver: laplaceTetDecomposition
--> FOAM FATAL ERROR : solver table is empty
From function motionSolver::New(const polyMesh& mesh)
in file motionSolver/motionSolver.C at line 141.
FOAM exiting
Code is basically just this (for the moment, nothing solving, just trying to move a mesh):
Info<< "\nStarting time loop\n" << endl;
autoPtr<foam::motionsolver> motionPtr = motionSolver::New(mesh);
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
mesh.movePoints(motionPtr->newPoints());
return(0);
File dynamicMeshDict looks like this:
dynamicFvMeshLib "libtetDecompositionMotionSolvers.so";
dynamicFvMesh dynamicMotionSolverFvMesh;
// twoDMotion yes;
solver laplaceTetDecomposition;
diffusion quadratic patchEnhanced;
frozenDiffusion off;
distancePatches 0 ();
I also have a file motionU, not showing it here (could do so, if needed, of course..)
Any hint to get me continuing would be very much appreciated - I am stuck a little
Thank you!
Thomas
tehache is offline   Reply With Quote
Old   May 14, 2007, 04:51
Default Ooops sorry for spamming - dir
Thomas Jung
Ooops sorry for spamming - directly after posting I had the great idea to add these libraries
-ldecompositionMethods \
-ltetDecompositionMotionSolvers \
... and its fine now
Sorry again for abusing your attention
Old   May 14, 2007, 04:59
Default you may want also to have a lo
rafal zietara
rafal is on a distinguished road
you may want also to have a look on utilities:
moveDynamicMesh
moveEngineMesh
moveMesh
rafal
rafal is offline   Reply With Quote
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 10:06
[Commercial meshers] FOAM FATAL ERROR points deallocated hoerl OpenFOAM Meshing & Mesh Conversion 0 October 30, 2006 07:47
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 14:20
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 04:37
