Only bsolving for pb reported
Old   February 27, 2007, 03:15
Default hello, when I start a simul
marc de boer
marc is on a distinguished road
hello,
when I start a simulation (for example the cavity case) only 'solving for p' is reported with some other info, but I am missing 'solving for U' or so. With an other case in simpleFoam still only 'solving for p' is reported. U, k, epsilon etc. are missing...does anybody know why and if it matters?
thanks, Marc
marc is offline   Reply With Quote
Old   April 10, 2007, 19:31
Default OK this is ridiculous. I have
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
OK this is ridiculous. I have the same problem on one case and all others run fine. In fact I know that the velocities are getting computed as I find the saved results in the time-directory.
I have included the entire simpleFoam case. Can someone try it on their machine and report whether velocity calculations are printed in the log file?
Thanks!
The case can be found here:
http://www.ualberta.ca/~madhavan/sample.tar.gz
msrinath80 is offline   Reply With Quote
Old   April 12, 2007, 18:19
Default Hi pUI, can you report this
Mattijs Janssens
mattijs is on a distinguished road
Hi pUI,
can you report this as a bug?
mattijs is offline   Reply With Quote
Old   April 12, 2007, 18:59
Default Will do Mattijs. Thanks.
reported mass flow differs from monitored mass flo London FLUENT 4 July 17, 2008 12:44
Problematic geometry reported smillerhh FLUENT 1 December 7, 2006 11:42
