Header files
Like Tree1Likes
  • 1 Post By gschaider
Old   September 10, 2006, 02:47
Default Hi guys Where can I access
shuo
Hi guys
Where can I access the source codes for header files like fvCFD.H, createMesh.N?
Shuo
Old   September 10, 2006, 03:38
Default You'll find them in your Foam-
Assistant Moderator
Bernhard Gschaider
You'll find them in your Foam-Installation with this command:
find $FOAM_SRC -name fvCFD.H
or
find $FOAM_SRC -path "*lnInclude" -prune -or -name fvCFD.H -exec xemacs {} \;
if you want an immediate look at it
meshman likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Header files not found kalldrexx OpenFOAM Installation 5 September 13, 2022 07:57
header file for strings in udf sangeeta FLUENT 4 July 6, 2007 00:52
how to add header file shanu FLUENT 1 February 14, 2006 09:00
uhf.h header file giridhar_tech FLUENT 0 February 7, 2006 07:51
