This mesh contains patches of type empty but is not 1D or 2D
Old   August 22, 2006, 09:46
Default Hi, I tried to remove a wa
oric
I tried to remove a wall from the cavity case (tutorial/icoFoam/cavity) so I changed the blockMeshDict by moving a patch from fixedWall to frontAndBack in the boundary conditions :
wall fixedWalls
(2 6 5 1)
(1 5 4 0)
empty frontAndBack
(0 4 7 3)
(0 3 2 1)
(4 5 6 7)
Then I run blockMesh without problem but when I run icoFoam I get :
--> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
I agree, the mesh is not 1D or 2D, but the cavity example neither and it works with "empty" patches !
What should I do ? My goal is to run a NS simulation in a open space over a ground with obstacles.
TIA
Olivier.
Old   August 23, 2006, 03:57
Default empty patches are not included
Mattijs Janssens
empty patches are not included in any calculation. They are really only useful for front and back of a pure 2D simulation. This also means your domain should be only one celllayer thick (since otherwise you'd still have internal faces in the cross direction)
The cavity tutorial is a 2D simulation (no cross flow, no gradients in cross direction apart from truncation errors)
Old   August 23, 2006, 08:17
Default ok, so I used patch in
oric
ok, so I used
patch in
(0 4 7 3)
patch out
(2 6 5 1)
and the right B.C. in 0/p and 0/U and it is ok.
Thanks,
Olivier.
Old   May 15, 2009, 20:21
Default This mesh contains patches of type empty but is not 1D or 2D
Nugroho Adi
mahaputra is on a distinguished road
Dear All
since I am a beginner, i try to make a 2D mesh by manual n blockMesh
like shown below :
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1e-3;
vertices
(250 0 0)
(300 0 0)
(250 100 0)
(300 100 0)
(100 100 0)
(250 100 0)
(300 100 0)
(0 175 0)
(100 175 0)
(100 175 0)
(250 175 0)
(300 175 0)
(0 225 0)
(100 225 0)
(100 225 0)
(250 225 0)
(300 225 0)
(100 550 0)
(250 550 0)
(300 550 0)
(300 550 0)
(400 550 0)
(100 600 0)
(250 600 0)
(300 600 0)
(300 600 0)
(400 600 0)
(250 0 1)
(300 0 1)
(250 100 1)
(300 100 1)
(100 100 1)
(250 100 1)
(300 100 1)
(0 175 1)
(100 175 1)
(100 175 1)
(250 175 1)
(300 175 1)
(0 225 1)
(100 225 1)
(100 225 1)
(250 225 1)
(300 225 1)
(100 550 1)
(250 550 1)
(300 550 1)
(300 550 1)
(400 550 1)
(100 600 1)
(250 600 1)
(300 600 1)
(300 600 1)
(400 600 1)
blocks
hex (0 1 3 2 27 28 30 29) (10 20 1) simpleGrading (1 1 1)
hex (4 5 10 9 31 32 37 36) (30 15 1) simpleGrading (1 1 1)
hex (5 6 11 10 32 33 38 37) (10 15 1) simpleGrading (1 1 1)
hex (7 8 13 12 34 35 40 39) (20 10 1) simpleGrading (1 1 1)
hex (9 10 15 14 36 37 42 41) (30 10 1) simpleGrading (1 1 1)
hex (10 11 16 15 37 38 43 42) (10 10 1) simpleGrading (1 1 1)
hex (14 15 18 17 41 42 45 44) (30 65 1) simpleGrading (1 1 1)
hex (15 16 19 18 42 43 46 45) (10 65 1) simpleGrading (1 1 1)
hex (17 18 23 22 44 45 50 49) (30 10 1) simpleGrading (1 1 1)
hex (18 19 24 23 45 46 51 50) (10 10 1) simpleGrading (1 1 1)
hex (20 21 26 25 47 48 53 52) (20 10 1) simpleGrading (1 1 1)
edges
patches
wall walls
(0 2 29 27)
(1 3 30 28)
(4 5 32 31)
(4 9 36 31)
(6 11 38 33)
(7 8 35 34)
(11 16 43 38)
(12 13 40 39)
(14 17 44 41)
(16 19 46 43)
(17 22 49 44)
(20 21 48 47)
(22 23 50 49)
(23 24 51 50)
(25 26 53 52)
patch inlet
(7 12 39 34)
patch outletBottom
(0 1 28 27)
patch outletTop
(21 26 53 48)
empty frontAndBack
(0 1 3 2)
(4 5 10 9)
(5 6 11 10)
(9 10 15 14)
(10 11 16 15)
(14 15 18 17)
(15 16 19 18)
(17 18 23 22)
(18 19 24 23)
(7 8 13 12)
(20 21 26 25)
(27 28 30 29)
(31 32 37 36)
(32 33 38 37)
(36 37 42 41)
(37 38 43 42)
(41 42 45 44)
(42 43 46 45)
(44 45 50 49)
(45 46 51 50)
(34 35 40 39)
(47 48 53 52)
mergePatchPairs
i run checkMesh, and it said :
Mesh OK.
but, i got this following error message when tried to run my case (im using dieselFoam) :
Creating field DpDt
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148.
FOAM exiting
anybody can help me please
really really need help
many thanks
mahaputra is offline   Reply With Quote
Old   May 16, 2009, 05:42
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Nugroho
I do not know if it is the source of all your problems, however you have multiple defined points, e.g.:
(300 100 0)
(100 100 0)
(250 100 0)
(300 100 0)
and if you do not use the same points to define two blocks with common boundary, it will not automatically be merged. Remove all duplicate points and try again. By the way, the blockMesh do tell you that something is wrong by:
Default patch type set to empty
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576
Found 6 undefined faces in mesh; adding to default patch.
This is a valuable warning, because you have manually made the front and back patches.
Good luck,
Niels
ngj is offline   Reply With Quote
Old   May 16, 2009, 06:09
Nugroho Adi
Originally Posted by ngj View Post
Hi Nugroho
(300 100 0)
(100 100 0)
(250 100 0)
(300 100 0)
--> FOAM Warning :
Good luck,
Niels
Ok
i will remove the duplicate point
but, what do you mean with ''I have multiple defined points'' ? i still didnt understand
Thanks Niels
Old   May 16, 2009, 06:56
ngj
The point (300 100 0) is among others defined in the vertices-list more than once.
Old   May 16, 2009, 08:22
Nugroho Adi
Dear Niels
i have removed the duplicate points
like shown below :
FoamFile
version 2.0;
format ascii;
class dictionary;
vertices
(250 0 0) //0
(300 0 0) //1
(300 100 0) //2
(250 100 0) //3
(100 100 0) //4
(0 175 0) //5
(100 175 0) //6
(250 175 0) //7
(300 175 0) //8
(300 225 0) //9
(250 225 0) //10
(100 225 0) //11
(0 225 0) //12
(100 550 0) //13
(250 550 0) //14
(300 550 0) //15
(400 550 0) //16
(400 600 0) //17
(300 600 0) //18
(250 600 0) //19
(100 600 0) //20
(250 0 1) //21
(300 0 1) //22
(300 100 1) //23
(250 100 1) //24
(100 100 1) //25
(0 175 1) //26
(100 175 1) //27
(250 175 1) //28
(300 175 1) //29
(300 225 1) //30
(250 225 1) //31
(100 225 1) //32
(0 225 1) //33
(100 550 1) //34
(250 550 1) //35
(300 550 1) //36
(400 550 1) //37
(400 600 1) //38
(300 600 1) //39
(250 600 1) //40
(100 600 1) //41
blocks
hex (0 1 3 2 21 22 23 24) (10 20 1) simpleGrading (1 1 1)
hex (4 3 7 6 25 24 28 27) (30 15 1) simpleGrading (1 1 1)
hex (3 2 8 7 24 23 29 28) (10 15 1) simpleGrading (1 1 1)
hex (5 6 11 12 26 27 32 33) (20 10 1) simpleGrading (1 1 1)
hex (6 7 10 11 27 28 31 32) (30 10 1) simpleGrading (1 1 1)
hex (7 8 9 10 28 29 30 31) (10 10 1) simpleGrading (1 1 1)
hex (11 10 14 13 32 31 35 34) (30 65 1) simpleGrading (1 1 1)
hex (10 9 15 14 31 30 36 35) (10 65 1) simpleGrading (1 1 1)
hex (13 14 19 20 34 35 40 41) (30 10 1) simpleGrading (1 1 1)
hex (14 15 18 19 35 36 39 40) (10 10 1) simpleGrading (1 1 1)
hex (15 16 17 18 36 37 38 39) (20 10 1) simpleGrading (1 1 1)
edges
patches
wall walls
(0 3 24 21)
(1 2 23 22)
(4 3 24 25)
(4 6 27 25)
(2 8 29 23)
(5 6 27 26)
(8 9 30 29)
(12 11 32 33)
(11 13 34 32)
(9 15 36 30)
(13 20 41 34)
(15 16 37 36)
(20 19 40 41)
(19 18 39 40)
(18 17 38 39)
patch inlet
(5 12 33 26)
patch outletBottom
(0 1 22 21)
patch outletTop
(16 17 38 37)
empty frontAndBack
(0 1 3 2)
(4 3 7 6)
(3 2 8 7)
(6 7 10 11)
(7 8 9 10)
(11 10 14 13)
(10 9 15 14)
(13 14 19 20)
(14 15 18 19)
(5 6 11 12)
(15 16 17 18)
(21 22 23 24)
(25 24 28 27)
(24 23 29 28)
(27 28 31 32)
(28 29 30 31)
(32 31 35 34)
(31 30 36 35)
(34 35 40 41)
(35 36 39 40)
(26 27 32 33)
(36 37 38 39)
mergePatchPairs
but i got this error message when i tried run blockMesh :
face 0 in patch 0 does not have neighbour cell face: 4(0 3 24 21)#0 Foam::error:rintStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#3 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/home/user/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#6 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#7 main in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 __gxx_personality_v0 in "/home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 125.
FOAM aborting
Aborted
i dont understand why this error message came? since i checked, for the face 0 in patch 0 (wall) it has neighbour cell .
so why this error came ?
Old   May 16, 2009, 09:45
ngj
The block
is ill-defined. I suppose it needs to be:
hex (0 1 2 3 21 22 23 24) (10 20 1) simpleGrading (1 1 1)
Best regards,
Niels
Old   May 16, 2009, 09:52
Nugroho Adi
oh my God!
i didnt see it. Thanks Niels.
now my simulation is running
Old   July 10, 2009, 14:52
sesha
hamsadhwani8 is on a distinguished road
I am trying to run a 3D case in interFoam. I am able to run a case with just 1 cell in the z-direction. However, when I try to increase the number of cells in this direction i get the following error while running the interfoam case. There is no problem with the mesh as checkMesh indicates. Can someone comment on this please? Below is the error i get at execution, followed by my blockMesh file. Thanks
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
--> FOAM Warning :
From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
in file /Network/Servers/controller.cluster/Homedir/stsriniv/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252
Reading "/Homedir/stsriniv/OpenFOAM/stsriniv-1.5/run/tutorials/interFoam/dropletShear_inletU/0/pd:utlet" from line 34 to line 35
expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
FOAM exiting
My blockMesh file is:
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1.0;//0.01; //0.146;
vertices
(-5.0 -1.5 -2.5)
(5.0 -1.5 -2.5)
(5.0 0 -2.5)
(-5.0 0 -2.5)
(5.0 1.5 -2.5)
(-5.0 1.5 -2.5)
(-5.0 -1.5 2.5)
(5.0 -1.5 2.5)
(5.0 0 2.5)
(-5.0 0 2.5)
(5.0 1.5 2.5)
(-5.0 1.5 2.5)
blocks
hex (0 1 2 3 6 7 8 9) (200 30 4) simpleGrading (1 1 1)
hex (3 2 4 5 9 8 10 11) (200 30 4) simpleGrading (1 1 1)
// hex (0 1 2 3 6 7 8 9) (15 100 1) simpleGrading (1 1 1)
// hex (3 2 4 5 9 8 10 11) (15 100 1) simpleGrading (1 1 1)
// hex (5 4 6 7 15 14 16 17) (15 100 1) simpleGrading (1 1 1)
// hex (7 6 8 9 17 16 18 19) (35 100 1) simpleGrading (1 1 1)
edges
patches
patch inlet1
(1 2 8 7)
patch inlet2
(3 5 11 9)
patch outlet
(2 4 10 8)
(0 3 9 6)
patch movingwall1 //atmosphere
(4 5 11 10)
// (0 6 7 1)
patch movingwall2 //atmosphere
// (4 5 11 10)
(0 6 7 1)
mergePatchPairs
hamsadhwani8 is offline   Reply With Quote
Old   July 10, 2009, 15:54
ngj
The above is the answer you seek.
Best regards
Miels
Old   July 10, 2009, 16:11
sesha
Hi Niels,
Thanks for the quick reply. However, I did not understand that error. All the patches are either inlets/outlets or walls. What is this empty patch? Is it referring to the the front and back surfaces? I have used the exact same blockMesh file for a 2D case by simply changing the block thickness in the z direction and setting the number of cells to 1. If you could throw more light on this.
Thanks,
S
Old   July 13, 2009, 03:39
ngj
Hi Sechasai
The only thing I can come up with, is that sometimes I have experienced that the constant/polyMesh/boundary file is not updated.
Try deleting it and re-blockMesh, then it should be the correct file, and hopefully it will solve your problem.
Best regards,
Niels
Old   August 4, 2009, 15:16
anthony
bobby is on a distinguished road
I have the same problem. I am trying to simulate the rising of bubble on a plate.
I already used InterFoam (with the same mesh and without errors) but I need to compare my results using InterDyMFoam.
The same message as above appears :
Selected 176 cells for refinement out of 146800.
Refined from 146800 to 148032 cells.
Selected 0 split points out of a possible 176.
Execution time for mesh.update() = 2.96 s
FOAM exiting
Here, is my blockMeshDict,
| \\ / O peration | Version: 1.4 |
| \\ / A nd | Web: http://www.openfoam.org |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
convertToMeters 1;
vertices
(0 0 0)
(0.004 0 0)
(0.070 0 0)
(0.08 0 0)
(0 0 0.013)
(0.004 0 0.013)
(0.070 0 0.013)
(0.08 0 0.013)
(0 0 0.015)
(0.004 0 0.015)
(0.070 0 0.015)
(0.08 0 0.015)
(0 0 0.02)
(0.004 0 0.02)
(0.070 0 0.02)
(0.08 0 0.02)
(0 0.02 0)
(0.004 0.02 0)
(0.070 0.02 0)
(0.08 0.02 0)
(0 0.02 0.013)
(0.004 0.02 0.013)
(0.070 0.02 0.013)
(0.08 0.02 0.013)
(0 0.02 0.015)
(0.004 0.02 0.015)
(0.070 0.02 0.015)
(0.08 0.02 0.015)
(0 0.02 0.02)
(0.004 0.02 0.02)
(0.070 0.02 0.02)
(0.08 0.02 0.02)
blocks
hex (0 1 17 16 4 5 21 20) (40 1 130) simpleGrading (1 1 1)
hex (1 2 18 17 5 6 22 21) (660 1 130) simpleGrading (1 1 1)
hex (2 3 19 18 6 7 23 22) (100 1 130) simpleGrading (1 1 1)
hex (4 5 21 20 8 9 25 24) (40 1 20) simpleGrading (1 1 1)
hex (6 7 23 22 10 11 27 26) (100 1 20) simpleGrading (1 1 1)
hex (8 9 25 24 12 13 29 28) (40 1 50) simpleGrading (1 1 1)
hex (9 10 26 25 13 14 30 29) (660 1 50) simpleGrading (1 1 1)
hex (10 11 27 26 14 15 31 30) (100 1 50) simpleGrading (1 1 1)
edges
patches
wall tankWall
(0 16 17 1)
(1 17 18 2)
(2 18 19 3)
(0 4 20 16)
(4 8 24 20)
(8 12 28 24)
(12 13 29 28)
(13 14 30 29)
(14 15 31 30)
patch inout
(15 11 27 31)
(11 7 23 27)
(7 3 19 23)
wall heatedPlate
(5 6 22 21)
wall adiaPlate
(9 5 21 25)
(9 25 26 10)
(10 26 22 6)
empty backAndFront
(0 1 5 4)
(4 5 9 8)
(8 9 13 12)
(1 2 6 5)
(9 10 14 13)
(2 3 7 6)
(6 7 11 10)
(10 11 15 14)
(16 17 21 20)
(20 21 25 24)
(24 25 29 28)
(17 18 22 21)
(25 26 30 29)
(18 19 23 22)
(22 23 27 26)
(26 27 31 30)
mergePatchPairs
Can someone help me please?
Best Regards
bobby is offline   Reply With Quote
Old   August 6, 2009, 08:13
Sandy Lee
sandy is on a distinguished road
Hi guys, when I import my gambit .neu file into OpenFOAM, I check the mesh is OK. However, after I change the frontandback into empty (2D mesh) and check the mesh again, I get error message as follow:
Exec : checkMesh
Date : Aug 07 2009
Time : 01:55:47
Host : localhost.localdomain
PID : 5190
Case : /root/OpenFOAM/root-1.5/run/tutorials/LesInterPhaseChangeFoam/Hydrofoil/Sixdegree
nProcs : 1
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
internal points: 0
faces: 181229
internal faces: 89815
cells: 45174
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 45174
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
inlet 103 208 ok (non-closed singly connected)
outlet 158 318 ok (non-closed singly connected)
up 237 476 ok (non-closed singly connected)
down 236 474 ok (non-closed singly connected)
frontandback 90348 91414 ok (non-closed singly connected)
foil 332 664 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-10 -10 0) (30 10 0.007)
Mesh (non-empty) directions (1 1 0)
Mesh (non-empty, non-wedge) dimensions 2
***Number of edges not aligned with or perpendicular to non-empty directions: 38113
<<Writing 76226 points on non-aligned edges to set nonAlignedEdges
Boundary openness (-8.9509e-24 9.15928e-22 -1.31298e-19) OK.
Max cell openness = 2.56232e-16 OK.
Max aspect ratio = 287.879 OK.
Minumum face area = 2.19292e-05. Maximum face area = 0.452831. Face area magnitudes OK.
Min volume = 2.41268e-07. Max volume = 0.00316982. Total volume = 5.29651. Cell volumes OK.
Mesh non-orthogonality Max: 39.8412 average: 5.87407
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.763965 OK.
Failed 1 mesh checks.
End
What's wrong with it? Could somebody help me out? Thanks a lot.
sandy is offline   Reply With Quote
Old   August 10, 2009, 04:29
Sandy Lee
Maybe I should try to get the mesh by the great Tool snappyHexMesh?
Old   August 14, 2009, 01:49
Steve Hansel
hansel is on a distinguished road
Comment deleted
hansel is offline   Reply With Quote
Old   December 8, 2009, 12:15
tgj
tgj is on a distinguished road
hi,
as a beginner in OpenFOAM, i'm trying to run a 2D "virtual wind tunnel" with a square shaped obstacle using simplefoam. This is my BlockMeshDict:
convertToMeters 0.05;
vertices
(0 0 0)
(20 0 0)
(20 5 0)
(0 5 0)
(0 0 0.1)
(20 0 0.1) //Z5
(20 5 0.1)
(0 5 0.1)
(40 5 0)
(40 10 0)
(20 10 0) //Z10
(40 5 0.1)
(40 10 0.1)
(20 10 0.1)
(20 -5 0)
(40 -5 0) //Z15
(40 0 0)
(20 -5 0.1)
(40 -5 0.1)
(40 0 0.1)
(27 1 0) //Z20
(32 1 0)
(32 4 0)
(27 4 0)
(27 1 0.1)
(32 1 0.1) //Z25
(32 4 0.1)
(27 4 0.1)
(27 0 0)
(32 0 0)
(32 0 0.1) //Z30
(27 0 0.1)
(27 5 0)
(32 5 0)
(32 5 0.1)
(27 5 0.1) //Z35
(20 1 0)
(20 4 0)
(20 4 0.1)
(20 1 0.1)
(40 1 0) //Z40
(40 4 0)
(40 4 0.1)
(40 1 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (20 5 1) simpleGrading (1 1 1)
hex (2 8 9 10 6 11 12 13) (20 5 1) simpleGrading (1 1 1)
hex (14 15 16 1 17 18 19 5) (20 5 1) simpleGrading (1 1 1)
hex (1 28 20 36 5 31 24 39) (7 1 1) simpleGrading (1 1 1)
hex (29 16 40 21 30 19 43 25) (8 1 1) simpleGrading (1 1 1)
hex (36 20 23 37 39 24 27 38) (7 3 1) simpleGrading (1 1 1)
hex (21 40 41 22 25 43 42 26) (8 3 1) simpleGrading (1 1 1)
hex (37 23 32 2 38 27 35 6) (7 1 1) simpleGrading (1 1 1)
hex (22 41 8 33 26 42 11 34) (8 1 1) simpleGrading (1 1 1)
hex (28 29 21 20 31 30 25 24) (5 1 1) simpleGrading (1 1 1)
hex (23 22 33 32 27 26 34 35) (5 1 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 3 7 4)
patch outlet
(16 40 43 19)
(40 41 42 43)
(41 8 11 42)
wall walls
(0 1 5 4)
(3 7 6 2)
(2 10 13 6)
(10 9 12 13)
(8 9 12 11)
(15 16 19 18)
(14 15 18 17)
(14 1 5 17)
(20 21 25 24)
(23 22 26 27)
(20 24 27 23)
(21 22 26 25)
empty frontAndBack
(0 1 2 3)
(4 5 6 7)
(2 8 9 10)
(6 11 12 13)
(14 15 16 1)
(17 18 19 5)
(1 28 20 36)
(5 31 24 39)
(29 16 40 21)
(30 19 43 25)
(28 29 21 20)
(31 30 25 24)
(23 22 33 32)
(27 26 34 35)
(36 20 23 37)
(39 24 27 38)
(21 40 41 22)
(25 43 42 26)
(37 23 32 2)
(38 27 35 6)
(22 41 8 33)
(26 42 11 34)
mergePatchPairs
blockmesh works but displays the warning:
--> FOAM Warning :
in file C:\tmp\OpenFOAM-1.5\src\OpenFOAM\meshes\polyMesh\polyMeshFromShape Mesh.C at line 576
Found 12 undefined faces in mesh; adding to default patch.
when i try to run simplefoam, i get:
Programme terminated with errors: exit code 1, status 0.
Error messages:
in file C:\tmp\OpenFOAM-1.5\src\finiteVolume\fields\fvPatchFields\constrai nt\empty\/emptyFvPatchField.C at line 148.
FOAM exiting
i really don't know where those undefined patches are. Any help would be appreciated
tgj is offline   Reply With Quote
Old   December 8, 2009, 15:21
Steve Hansel
When I make my meshes, I always changed the undefined type from empty to patch. For some reason a default empty patch causes me problems too.
[blockMesh] C type mesh ivan_cozza OpenFOAM Meshing & Mesh Conversion 13 November 28, 2008 04:38
Empty cells in mesh Nikolaos FLOW-3D 2 October 21, 2008 23:17
Moving mesh forces on patches and turbulence solver jackdaniels83 OpenFOAM Running, Solving & CFD 3 May 31, 2007 10:29
First steps w moving mesh FOAM FATAL ERROR solver table is empty tehache OpenFOAM Running, Solving & CFD 2 May 14, 2007 04:59
Mesh Type rakib FLUENT 0 September 17, 2000 07:28
