KEpsilon and KOmega
Old   June 28, 2006, 01:53
Default Hello, I am fairly new to C
larry
larry is on a distinguished road
I am fairly new to CFD and I've just finished installing OpenFOAM on my laptop. For my research, I have to study a problem with a relatively simple geometry (two flows mixing at the entrance of a cylinder. The cylinder has a diaphragm [circular corona] generating turbulence. The Reynolds range from 13000 to 90000. The system has a cylindrical symmetry.).
I wonder: are the K-Epsilon and K-Omega models implemented in OpenFOAM? Are they any difficult to use?
Many thanks
Larry
larry is offline   Reply With Quote
Old   June 28, 2006, 19:48
Default Q) Is k-epsilon implemented?
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
A) http://www.opencfd.co.uk/openfoam/tu...tml#turbulence
I believe that k-omega has more or less the same structure as k-epsilon. If you are strong in C++, it would be nice if you could implement it and pass it upstream. If I remember correctly, there was a discussion about it sometime back. Search this forum using 'omega' as the keyword.
Regarding the difficulty in usage, I don't think any model is very difficult to use. For instance, you could very easily follow the lid-driven cavity tutorial and get started quickly.
msrinath80 is offline   Reply With Quote
Old   June 28, 2006, 20:57
Default I'm new to OF as well, but hav
Richard Morgans
rmorgans is on a distinguished road
I'm new to OF as well, but have had a very small experience implementing the k-omega model in CFX quite a few years ago
http://www.cfd.com.au/cfd_conf99/papers/068MORG.PDF
If I can be of any assistance, please contact me.
It might be a good way to learn OF
Cheers
Rick
rmorgans is offline   Reply With Quote
Old   June 29, 2006, 01:38
Default Alright. Thanks both of you fo
larry
Alright. Thanks both of you for your advice. I have to do some reading first. I'll post again for sure later on.
Cheers
Lorenzo
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Kepsilon BC and intialization podallaire OpenFOAM Running, Solving & CFD 0 October 17, 2007 20:29
Komega equation doug OpenFOAM Running, Solving & CFD 6 July 18, 2007 03:09
Komega turbulence model jasonb OpenFOAM Running, Solving & CFD 6 August 29, 2006 08:46
Komega turbulent viscosity model guggi OpenFOAM Running, Solving & CFD 3 May 18, 2006 20:07
