March 29, 2006, 10:30 |
I'm trying to comput
I'm trying to compute several cases with Open Foam to compare with Fluent results. My first case is a 2d straight plane with a velocity inlet at left, an outflow at the top and the right and a wall condition at the bottom. My second case is a tunnel in three dimensions with lateral wall, a velocity inlet, and an outflow. So with Fluent my first case required about 20 minutes to be converged and my second 30 minutes. With OpenFoam I have set the Courant Number round 0.7. The computation time is too long and I want to improve this time. So is it possible to use an scheme which is stable for every courant number as "segregated" and "coupled-implicit" in Fluent. Greetings |
computing Nusselt number in a cavity | Shoaib | FLUENT | 1 | June 23, 2009 04:22 |
Computing time | Aditya | Main CFD Forum | 1 | September 21, 2006 08:50 |
Time for moving on to 64-bit computing? | Dr. Bian | CFX | 15 | June 19, 2006 10:03 |
Computing time | Liaqat Khan | Siemens | 2 | August 10, 2001 08:27 |
Computing time | Liaqat Khan | Main CFD Forum | 1 | March 29, 2001 09:53 |
