About icoFoam case
Old   December 14, 2005, 11:09
Default Dear all, I am trying to ru
Guoxiang
liugx212 is on a distinguished road
Dear all,
I am trying to run the icoFoam cavity case with the block size of 92*92*32 and defult sets. But I was told the error of time as follows. Could you please help me see and give advice?
Thanks a lot.
Errors:
Time = 0.02
Mean and max Courant Numbers = 0.109749 132.97
BICCG: Solving for Ux, Initial residual = 0.769511, Final residual = 9.41873e-06, No Iterations 38
BICCG: Solving for Uy, Initial residual = 0.725626, Final residual = 3.13877e-06, No Iterations 36
BICCG: Solving for Uz, Initial residual = 0.8086, Final residual = 9.13794e-06, No Iterations 35ICCG: Solving for p, Initial residual = 0.953251, Final residual = 9.12515e-07, No Iterations 265
time step continuity errors : sum local = 3.04285e-07, global = 1.32364e-18, cumulative = 1.65714e-18
ICCG: Solving for p, Initial residual = 0.841697, Final residual = 9.02924e-07, No Iterations 242
time step continuity errors : sum local = 1.65841e-06, global = 5.28474e-18, cumulative = 6.94188e-18
ExecutionTime = 192.11 s
Time = 0.025
Mean and max Courant Numbers = 1.37811 15395.5
BICCG: Solving for Ux, Initial residual = 0.997305, Final residual = 0.0301471, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 0.997675, Final residual = 15.8377, No Iterations 1001BICCG: Solving for Uz, Initial residual = 0.999334, Final residual = 0.00554499, No Iterations 1001
ICCG: Solving for p, Initial residual = 0.999822, Final residual = 9.36367e-07, No Iterations 124
time step continuity errors : sum local = 0.00903109, global = -3.98103e-15, cumulative = -3.97409e-15
ICCG: Solving for p, Initial residual = 0.998574, Final residual = 9.58777e-07, No Iterations 132
time step continuity errors : sum local = 5.25563, global = 4.08839e-11, cumulative = 4.08799e-11ExecutionTime = 748.68 s
Time = 0.03
Mean and max Courant Numbers = 1.61369e+06 5.99557e+10
BICCG: Solving for Ux, Initial residual = 1, Final residual = 1, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 1, Final residual = 1, No Iterations 1001
BICCG: Solving for Uz, Initial residual = 1, Final residual = 1, No Iterations 1001
ICCG: Solving for p, Initial residual = 1, Final residual = 51.6963, No Iterations 5001
time step continuity errors : sum local = 2.80935e+17, global = 2.2091, cumulative = 2.2091
ICCG: Solving for p, Initial residual = 1, Final residual = 56.148, No Iterations 5001
time step continuity errors : sum local = 7.65932e+26, global = -1.49149e+09, cumulative = -1.49149e+09
ExecutionTime = 1827.63 s
End
liugx212 is offline   Reply With Quote
Old   December 14, 2005, 11:52
Default I may be wrong, but looks like
Charles Ju
ploceus is on a distinguished road
I may be wrong, but looks like your mesh is too fine. Maybe you can try to reduce time step.
Regards.
ploceus is offline   Reply With Quote
Old   December 14, 2005, 12:01
Default Dear Charles Ju: Thanks for
Guoxiang
Dear Charles Ju:
Thanks for your advice. my using time step is 0.005 and stop on 0.03. writeInterval is 1. Please give more details.
Thanks deeply.
Guoxiang
Old   December 14, 2005, 12:34
Default Hi. Maybe time step = 0.001 o
Charles Ju
Hi.
Maybe time step = 0.001 or 0.0001?
Or you could increase cell sizes.
Also wrong boundary conditions will cause diverging solutions. Check them too.
Regards.
Old   December 14, 2005, 12:47
Default Dear Charles Ju: Thanks ag
Guoxiang
Dear Charles Ju:
Thanks again. I will check as you said. By the way, the boundary conditions were checked which was ok by run checkMesh. I am not sure whether it is ok or not.
I will tell you after test.
Thanks deeply.
Guoxiang
Old   December 14, 2005, 13:14
Default Boundary condition are checked
liu
Xiaofeng Liu
liu is on a distinguished road
Boundary condition are checked by yourself, not checkMesh.
Do some coarse mesh calculation to see what will happen.
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   December 14, 2005, 13:15
Default Dear Charles Ju: I have ch
Guoxiang
Dear Charles Ju:
I have change as you said, but the problem is same. Do you have another advice?
Thanks deeply.
Guoxiang
Old   December 14, 2005, 15:40
Default Dear Xiaofeng: Thanks a lot
Guoxiang
Dear Xiaofeng:
Thanks a lot. Just now, I checked the boundary file. My nFaces is: 28704, but the startFace is: 798192 So I think something is wrong here since startFace is further more the nFace. Could you please give some advice?
Thanks deeply,
Guoxiang
Old   December 15, 2005, 15:59
Default Dear All, I still do not so
Guoxiang
Dear All,
I still do not solve this questions yet. I have changed to small time step and checked the boundary. It likes ok. But the "time step continuity errors :" problem is still here. Could you please help me?
Old   December 17, 2005, 13:44
Default Obviously something is wrong w
unoder
Obviously something is wrong with one of your files, so why don't you just copy a whole new/fresh icoFoam cavity case from inside /tutorials directory and then run blockMesh and icoFoam.
AFAIR there's also an .allrun file which works straight "out-of-the-box".
Old   December 17, 2005, 13:49
Default Dear Martin Jørgensen: Than
  #11
Guoxiang
Thanks for your help.
You mean I should use Allrun to instead of the blockMesh and icoFoam. Right?
Thanks again.
Guoxiang
Old   December 17, 2005, 14:29
Default Hi Guoxiang, I mean: (under
  #12
unoder
Hi Guoxiang,
I mean: (under linux), standing inside your working directory - that would probably be something like (can't exactly remember if this path is correct, however here we go):
cd /home/guoxiang/OpenFOAM/OpenFOAM-1.2/guoxiang-1.2/run/tutorials
I would then do a recursive remove on this directory that doesn't work "rm -rf icoFoam/cavity" - notice that you should make sure you have a backup somewhere of the original directory which in my place would be in something like /OpenFOAM/OpenFOAM-1.2/run/tutorials. If you did like in the readme file that ships with openfoam, you would also have a backup.
So, standing in your working directory:
"cp -r /OpenFOAM/OpenFOAM-1.2/run/tutorials/icoFoam/cavity (place you want your working copy like for instance .)"
Then ./allrun worked for me (blockMesh and icoFoam should also work) as far as I remember and once you made sure everything is okay, you can experiment by changing mesh grading etc (in blockMeshDict-file).
I assume you once already have solved this case, right?
Old   December 17, 2005, 17:43
  #13
Guoxiang
Thanks a lot.
Just now, I have tries as you said, But the problem is still same. Could you have another advice?
Thank you very much.
xiang
Old   December 18, 2005, 09:42
Default Yep, attach your case here in
  #14
unoder
Yep, attach your case here in a compressed file so others can download it and try for themselves.
Old   December 18, 2005, 13:28
Default Dear Martin Jørgensen: I ha
  #15
Guoxiang
I have a test when I reinstalled. But the question is still here. It is very strange. I use the cavity in icoFoam case. I have really no idea. I do not how to do?
Thanks a lot.
xiang
IcoFoam aap OpenFOAM Running, Solving & CFD 15 May 28, 2012 08:30
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
About phi in icoFoam kar OpenFOAM Running, Solving & CFD 3 February 20, 2008 05:20
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 16:52
IcoFoam on AIX 53 ds2taieb OpenFOAM Installation 1 March 24, 2006 03:22
