[Tutorials] Tutorial of how to plot residuals !
Like Tree344Likes
Prev Previous Post   Next Post Next
Old   April 30, 2009, 09:07
Default Tutorial of how to plot residuals !
Wolfgang Heydlauff
wolle1982 will become famous soon enough
Hi all,
since apearantly noone has an idea of how to plot the residuals of a calculation on-the-fly, I will give a small manual on that:
Tutorial on "How to plot the residuals (and forces) graphically on screen on-the-fly"
Step 1:
Start the calculation and make it write out a log-file. for example
turbFoam >log
"log" is the name of the log-file to be output. It is written into the main-case-folder.
Step 2:
If desired you can open a new console-window of the main-case-folder and follow the text-output by the command
tail -f log
"log" is the name of the log-file to be read in. To stop reading the file constantly just use Crtl+C
Step 3:
To plot the residuals graphically on the screen you can use gnuplot that is delivered with linux already.
Within the main-case-folder you have to put a text file with a name e.g. "Residuals"
(also see attachments).
The file should contain the following gnuplot properties:
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Iteration'
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\
"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\
"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\
"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,\
"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\
"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines
pause 1
reread
The pause-command sets the seconds till reload. Deletion makes it faster in some cases.
Execute the command
gnuplot Residuals -
in the main-case-folder.
Step 4:
Another good indicator for the calculations convergence is the forces-plot. Therefore you have to set the function in the controlDict that calculates the forces and forceCoeffs. See thread http://www.cfd-online.com/Forums/ope...es-of15-3.html or attachments.
Be sure to have the properties for gnuplot in the main-case-folder (see attachments).
You have the adapt the folder-name where the forceCoeffs.dat is inside before.
While the calculation runs you also can use the gnuplot command
gnuplot forceCoeffs -
in the main-case-folder. When the forces seem to not change any more, the pressure allocation must be constantly what makes the convergent case proofed.
Step5:
Plotting the real forces is also easy. Proceed identically like in "Step 4" but be sure to set
magUInf 1.0; //free stream velocity magnitude
lRef 1.0; //reference length
Aref 1.632653; //reference area
in the controlDict.
Using the attached text-files, remove the ".txt" first.
Hope that helps somebody.
Greetings,
Wolfgang
File Type: txt forceCoeffs.txt (369 Bytes, 6291 views)
File Type: txt Residuals.txt (656 Bytes, 9844 views)
File Type: txt functions.txt (506 Bytes, 5063 views)
wolle1982 is offline   Reply With Quote
plot residuals in multiregion solver val46 OpenFOAM 4 December 12, 2016 06:06
To Plot Residuals on the fly. neeraj OpenFOAM Running, Solving & CFD 5 October 2, 2013 06:23
[PyFoam] why pyFoamPlotRunner doesn't plot continuity residuals? immortality OpenFOAM Community Contributions 10 May 5, 2013 06:13
plot of residuals hawkeye321 OpenFOAM 5 December 7, 2012 09:05
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 16:01
