InterDyMFoam with GGI
Old   September 17, 2009, 03:38
Default InterDyMFoam with GGI
Sebastian Weiper
sebastianweiper is on a distinguished road
Hi Foamers,
I am trying to simulate a case with two fluids with a moving mehs. First i have looked at the interDyMFoam tutorials but these cases doesn´t fit to my Problem.
I take the tutorial case mixerGgi from icoDyMFoam and modify it for a simulation of 2 fluids. The Problem is that the Case doesn´t run.
So I modified the interDyMFoam Solver and delete everything that I get only the moving. This works fine.
But when I use the normal interDyMFoam solver i got a "Floiting point exception" and i don´t know where the Problem is.
Thank you for your Help
Sebastian
sebastianweiper is offline   Reply With Quote
Old   September 18, 2009, 03:20
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hi Sebastian,
I had a look at your case and the reason for floating point exception is caused by the initial boundary conditions for k and epsilon.
On the ggi patch I changed their uniform value to sth. different than 0 and added entries for k and epsilon to fvSchemes and fvSolution. Case is running now, see attached file.
Best,
Andreas
lord_kossity is offline   Reply With Quote
Old   September 18, 2009, 03:43
Sebastian Weiper
Thank you. This solved my Problem.
Software: OpenFOAM 1.5-dev
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
GGI in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 59 April 30, 2010 08:30
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 18:54
Periodic GGI, How to sponiar OpenFOAM Running, Solving & CFD 0 May 26, 2009 03:50
GGI ERCOFTAC and general questions david OpenFOAM Running, Solving & CFD 8 August 25, 2008 09:22
