OpenFOAM and fluid-structure interaction, biomedical applications
Old   January 20, 2010, 05:14
Default OpenFOAM and fluid-structure interaction, biomedical applications
Martin Vymazal
Martin_ is on a distinguished road
Hello OpenFOAM users,
I would like to do (potentially rather complex) simulation of blood flow including fluid-structure interaction. I googled a bit, but I'd still like to hear some more answers to the following questions:
- is OpenFOAM(-1.5-dev) able to solve the solid deformation using linear/nonlinear finite element approximation? I've read in several places that OpenFOAM can use FVM for both fluid and solid, but I didn't find an example of computation using FVM for fluid and FEM for solid part
- how difficult in your opinion it would be to add/modify coupling models between fluid and solid (this is actually what I'd like to play with). Does this involve digging very deep in the code?
- what is the order of accuracy and type (cell-vertex/cell-centered?) of the finite volume method in OpenFOAM (I'll be considering mainly unstructured meshes both in 2D and 3D)
I'll be grateful for any comments.
Best regards,
Martin Vymazal
Martin_ is offline   Reply With Quote
Old   January 21, 2010, 09:06
Hrvoje Jasak
Why don't you speak to Gavin Tabor at Uni Exeter or Alojz Ivankovic at UC Dublin - they have done a few of those and published papers as well.
Hrv
Hrvoje Jasak
Old   January 21, 2010, 09:17
Martin Vymazal
Hello Hrv,
thanks for the tip.
Best regards,
Martin Vymazal
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Heat transfer and fluid structure interaction at OpenFOAM Workshop Milan 2008 ztukovic OpenFOAM 0 March 28, 2008 11:17
Biological tissue fluid interaction bretttully OpenFOAM Running, Solving & CFD 1 February 19, 2008 13:26
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
PhD Positions Available Nano and MicroSystem Fluid Dynamics using OpenFOAM lynne OpenFOAM 0 March 8, 2006 09:54
