January 30, 2010, 22:37 |
Heat Transfer Coefficient
Tiago Macarios
I just installed openFOAM, so sorry if the question sounds stupid, but how do I set a heat transfer coefficient and prescribed heat flux in the laplacian solver?
I have this routine in fluent which I just simulate the solid with standard heat transfer conditions (heat tranfer coefficient, fixed temperature and prescribed heat flux) and I want to try to port it to openFOAM. Later I will need to run a optimizer and it looks like openFOAM can be reasonably faster. Any suggestion? Thanks |
January 31, 2010, 12:09 |
Eelco Gehring
You can set a fixed heat flux by setting a temperature gradient BC. Look in /0/T
There is a similar procedure for the fixed temperature. type gradient value uniform 8 (the gradient value) type fixedValue value uniform 400 (temperature value) |
January 31, 2010, 15:22 |
Tiago Macarios
Thank you, but how do I set the heat transfer coefficient? and the reference temperature?
January 31, 2010, 16:16 |
Eelco Gehring
I don't know an easy way to set that up.
January 31, 2010, 17:14 |
Tiago Macarios
Thats something unexpected =O
can you give me just give me some start instructions about the hard way? |
January 31, 2010, 17:44 |
Eelco Gehring
I would say that you have to implement a new boundary condition. I don't think this type of BC exists as of yet. However, I would search the forum thoroughly before doing anything else.
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Question on heat transfer coefficient!!! | Benny | FLUENT | 7 | June 7, 2005 09:25 |
