Problem: tetrahedral mesh and interFoam = bad results ? |
June 4, 2010, 09:43 |
C.Z.
i'm using the interFoam-solver (OF 1.6) to simulate a drop/wall-collision. Because it is much more comfortable and time efficient (compared to blockMesh), i create the geometry and mesh with Salome. In Salome i use the "Netgen(1D,2D,3D)"-mesher to create a tetrahedral mesh. From previous (and through experiments already validated) works, i pretty much know how the fluid-flow of the drop-impact - at least in the early phase of the simulation - should look like. In this case : The spreading wave-front has to be quiet smooth and spread nearly symmetrically in radial direction from the first point of contact between drop and wall. When using a hexahedral mesh, the results of the simulation match the experiments pretty good. Using a tetrahedral mesh (with approx. the same amount of cells and geometry as before) however, i get completely different and inappropriate results. The wave-front "splashes" immediatly and brakes into many little fragments. For a better clearness, i add these two pictures from topview (both show a quarter of a droplet shortly after it touches the wall and starting to spread) : With hexahedral mesh: With tetrahedral mesh: My questions are : Has someone an explanation for this discrepancy ? Is the interFoam-solver predestined for the use of hexahedral meshes ? What could be the reasons for this numerical error? Thanks in advance ! Best regards C.Z. |
October 10, 2015, 14:17 |
Angel Monsalve
Hi C.Z.
It's been a long long time since you posted this but I had a similar problem. Some time ago I was running a case using Salome in particular Netgen(1D,2D,3D) with a tetrahedral mesh. I know that all boundary conditions and solver specifications are correct since I have other simulations done with blockMesh and analytical solutions to compare to. Did you find any solution to this problem? |
interFoam 1.6.x vs 1.5 : same mesh, same bc but different results | nuovodna | OpenFOAM Running, Solving & CFD | 9 | June 14, 2010 05:45 |
setFields doesn't function for a tetrahedral mesh - interFoam | tommie | OpenFOAM Pre-Processing | 5 | April 15, 2010 03:32 |
[OpenFOAM] 'integrate variables' filter on a polyhedral mesh gives wrong results... | jbf | ParaView | 0 | September 4, 2009 04:08 |
Question on InterFoam moving mesh capabilities | ziv | OpenFOAM Running, Solving & CFD | 0 | April 23, 2008 09:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
