LES of a square cylinder
Old   June 24, 2010, 10:22
Question LES of a square cylinder
gfilip is on a distinguished road
I am having what I presume are inlet or grid quality issues with an LES case for a square cylinder. As can be seen in the attached images, the inflow to the left of the cylinder shows a strange behaviour with a variation of U (in attached image, coloured by U mag). My initial guess was that the aspect ratio or the grid quality overall is not good enough for LES. My grid does pass all checks inside of checkMesh.
I am using the dynamic Smagorinsky model (simple filter and cubeRootVol delta) with a hex + polyhedra (due to local refinement) grid of ~1.6 million cells. The Re = 22,000 and y+ average = ~6 after approximately 20 non-dimensional flow-overs, which I presume could be an issue as well as I am using the nuSgsWallFunction on the cylinder wall patch. I will try to construct a y+=1 grid and avoid the use of wall functions next.
My nuSgs file:
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    sides
        type            cyclic;
    cyl
//        type            zeroGradient;
        type            nuSgsWallFunction;
        value           uniform 1;
    sym
        type            symmetryPlane;
And my 0/U file:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.022 0 0);
boundaryField
    cyl
        type            fixedValue;
        value           uniform (0 0 0);
    inlet
        type            fixedValue;
        value           uniform (0.022 0 0);
    outlet
        type            zeroGradient;
    sides
        type            cyclic;
    sym
        type            symmetryPlane;
Is my setup incorrect, or is this purely a grid issue? Any hints would be greatly appreciated.
-Grzegorz
gfilip is offline   Reply With Quote
Old   June 24, 2010, 12:33
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Sorry, but I have to say your mesh looks bad, and is better not be called LES.
And what's more, it seems your inlet has a velocity profile, that's strange, isn't it?
You can upload your case file in tgz format, so that we could have a look, we need 0/ constant/ system/
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
cylinder, les, nusgs, square
LES of a square cylinder gfilip OpenFOAM 0 June 24, 2010 10:11
grids for flow over a square cylinder student Main CFD Forum 4 April 21, 2009 06:50
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 15:16
3D LES simulation of a circular cylinder fpz Main CFD Forum 3 June 20, 2005 19:50
drag calulation over a square cylinder sex00 Main CFD Forum 4 February 2, 2001 07:16
