How to model a fan fixing the mass flow rate?
Like Tree3Likes
Old   November 8, 2011, 09:51
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Dear Friends,
I have a problem with boundary conditions of my model. As it is shown, It is a centrifugal fan with a half sphere at the inlet and a duct at the outlet.
As I know, when the fan works at the maximum flow rate, Inlet(half sphere) would be total-Pressure and outlet would be static pressure equal to zero, which are:
Inlet:
P: totalPressure
U: pressureInletVelocity
Outlet:
P: fixedValue 0;
U: zeroGradient
But when we want to model the fan at lower flowrates (means the specific flowrate lower than maximum flowrate) what are the boundary conditions?!
As I know from previous investigations in fluent, it is massflow at inlet and outflow at outlet, but what is these BCs in OpenFOAM. I tried these things but residuals for pressure would'nt come down.
Inlet:
P: zeroGradient
U: massFlowRate
Outlet:
P: zeroGradient with pRefCell
U: -massFlowRate
or
Inlet:
P: zeroGradient
U: massFlowRate
Outlet:
P: fixedValue 0
U: zeroGradient
Anyone know the answer?!
Thanks anyway.
Mohammadreza Shetab
mrshb4 is offline   Reply With Quote
Old   November 12, 2011, 08:42
Mohammad.R.Shetab
still no answer?!!!!!!!
Old   September 13, 2013, 02:59
nash is on a distinguished road
Hi Mohammadreza Shetab,
have you manage to get a good result for the performance curve of the fan?
i'm now doing the same thing as yours.
I have used totalpressure for both inlet and outlet and as for the velocity i used zerogradient.
however the result seems to be under estimate when comparing it to the technical sheets from the fan manufacture.
any ideas?
and how can i set the boundaries of inlet and outlet for velocity and pressure when i want to vary the speed (rpm) and get the flowrate change?
tq
nash is offline   Reply With Quote
Old   September 13, 2013, 06:19
Mohammad.R.Shetab
In cases of turbomachineries several boundary conditions are well-known.
First, Total pressure at inlet(=0) and Static pressure at outlet(=0). The flow rate will then be changed by varying the value of static pressure for example(10,20,30,....).
The second is to use certain flow rates. In this case you should use different flow rates for inlet and zeroGradient at outlet for velocity. The pressure can be zerogradient at both inlet and outlet with a reference pressure or static pressure at outlet(if the flow reaches its fully-developed condition).
As your second question, I think the former set of boundary conditions would be fine (Total pressure at inlet(=0) and Static pressure at outlet(=0)).
Hope this helps
lpz456 likes this.
Old   October 1, 2013, 06:35
Hi reza,
regarding to your suggestion, is it right that i set the U boundary (for massflowrate 0.2)
inlet
        type            flowRateInletVelocity;
        massFlowRate    constant 0.2;
        value           uniform (0 0 0);
    outlet
        type            zeroGradient;
thanks
Old   October 1, 2013, 08:37
Mohammad.R.Shetab
That's right. However if you have any problem with imbalanced flow rates between inlet and outlet in the first time step, change the outlet to:
outlet
type zeroGradient;
value uniform (0 0 0.1);
(I supposed that the normal vector of the outlet is towards the Z-direction and has an area twice your inlet, so that the mass flow rate of both inlet and outlet in the first time-step get balanced and equals to 0.2)
Old   October 1, 2013, 08:46
outlet
type zeroGradient;
just as you mention, i got the imbalanced flow rates. I will give it a try.
Old   October 1, 2013, 09:00
outlet
type zeroGradient;
how about the pressure boundary?
i set it as below, and still imbalanced error appears
    outlet
        type            zeroGradient;
        value           uniform  0.;
    inlet
        type            zeroGradient;
        value           uniform  0.;
Old   October 1, 2013, 18:00
Mohammad.R.Shetab
You should specify the normal outlet velocity so that inlet and outlet have the same crossing flow rate. It can be calculated with simple math operations.
outlet
type zeroGradient;
value uniform 0.;
inlet
type zeroGradient;
value uniform 0.;
Your BC for pressure is right but you should specify a certain location as well as a reference pressure. You can add this in fvSolution with refCell and refPressure, as I remember.
Old   October 9, 2013, 05:05
hi,
u have done simulation with the centrifugal fan right?
  • you are using MRF as well isnt? for the simpleFoam OF220?
I have problem with BC.
I tried what u suggested but without a success.
Since i know the cross-area of my inlet, i tried using fixedValue for my
0/U BC for inlet
      type fixedValue;
      value uniform (0 0 -2.0723);
  • by doing this, is the velocity/mass flow will be constant through out the simulation? ( i need it to be constant)
0/U BC for outlet
    type            zeroGradient;
0/U BC for the rest (static walls)
        type            fixedValue;
0/p for inlet
        type            zeroGradient;
        value           uniform 0 ;
0/p for outlet
    type            fixedValue;
        value           uniform 0 ;
0/p for the rest of static walls i set
        type            zeroGradient;
        value           uniform 0 ;
after run it, i got a crazy result with velocity up to exp 8
anyone can help me with the BC setup??
MY MRF IN fvOption
[MRFSourceCoeffs
        origin      (0.0 0 0.);
        axis        (0 0 1);
        omega       806.342;
thank you
Old   October 11, 2013, 16:05
cfdivan is on a distinguished road
Hi nash,
The setup depends in what you want to test. If you want to test the max flow condition, which in turns means no pressure rise, you should setup the inlet and outlet BC' as pressure one. The value of the pressure should be the same at both BC's.
If you are looking for a another operating point in the curve of the fan, you may have two options...Either you impose the pressure rise or the massflow. I will say that likely it will be better impose the massflow and try to match the pressure rise.
I will suggest you to impose the massflow in the outlet and ambient pressure in the inlet. For a good accuracy, do it with sliding mesh instead of MRF.
Regards,
nash likes this.
cfdivan is offline   Reply With Quote
Old   October 11, 2013, 19:22
Originally Posted by cfdivan View Post
Hi nash,
Regards,
I tried the simulation but the pressure seems to be smaller than that of performance curve from manufacturer.
I read about the simplefoam solver, and the pressure is p/rho
If yes, then which rho is used by simplefoam? I need this to get the actual pressure.
Is there any possibility to change density in simplefoam?
I read that one could change the nu value, which actually change the density with nu=mu/rho.
Again can somebody point out what are default value for rho mu and nu use by simplefoam?
Old   October 18, 2013, 08:34
Default k Omega SST
  #53
Hi nash,
Regards,
the results now is only ok but i think i need to setup my k omega and nut dictionary since i used the tutorial case from motorbike.
for the inlet i set based on the discussion in this forum regarding k-omegaSST.
but for the wall i think its quit confusing since there is no guide or any confirmation for the setup, due to wall function.
Anyone can give me any hint??
Old   January 8, 2016, 18:11
Default fanBC PROBLEM
  #54
nasir musa yakubu
esujby is on a distinguished road
I am trying to, to use the fan BC to model a flow through a volumetric receiver, but i but after running splitMeshRegions -cellZones -overwrite , i get the following error:
parallels@ubuntu:~/OpenFOAM/OpenFOAM-3.0.x/chtMRF$ splitMeshRegions -cellZones -overwrite
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x-5ead44c48e61
Exec   : splitMeshRegions -cellZones -overwrite
Date   : Jan 08 2016
Time   : 23:04:08
Host   : "ubuntu"
PID    : 15339
Case   : /home/parallels/OpenFOAM/OpenFOAM-3.0.x/chtMRF
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:19
Writing region per cell file (for manual decomposition) to "/home/parallels/OpenFOAM/OpenFOAM-3.0.x/chtMRF/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/parallels/OpenFOAM/OpenFOAM-3.0.x/chtMRF/0/cellToRegion"
Region	Cells
0	54478
1	633047
2	335317
3	54477
4	111602
5	155631
6	202048
7	250781
8	296633
9	345799
10	396956
11	454148
12	499275
13	637728
14	312776
15	261108
16	345788
17	376148
18	410368
Region	Zone	Name
0	10	inlet
1	17	insulator
2	18	lens
3	1	outlet
4	15	s1
5	13	s2
6	16	s3
7	7	s4
8	9	s5
9	6	s6
10	5	s7
11	11	s8
12	14	s9
13	3	s10
14	2	s11
15	0	s12
16	12	s13
17	4	s14
18	8	s15
Sizes of interfaces between regions:
Interface	Region	Region	Faces
Reading volScalarField IDefault
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
    patch type cyclicAMI and patchField type calculated
file: /home/parallels/OpenFOAM/OpenFOAM-3.0.x/chtMRF/0/IDefault.boundaryField..* from line 25 to line 25.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /home/parallels/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 172.
FOAM exiting
i have the dropbox link to my case and a more detailed explanation of my issue in the following thread http://www.cfd-online.com/Forums/ope...tml#post580157
kind regards
esujby is offline   Reply With Quote
Old   January 18, 2016, 06:20
Default Radial Fan BC
  #55
ravi
ark704 is on a distinguished road
Hi all. I am a beginner in OpenFOAM and working on simulation of radial fan using MRF method (simpleFoam + fvOptions and using cyclicAMI). My workflow is described as follows :
1. Created 3 individual meshes (Suction, Impeller and Volute)
2. Merged them thru mergeMeshes
3. Changed the polyMesh/boundary file to incorporate cyclicAMI patches.
4. Did splitMesh to create cellzones
I am stuck at giving boundary conditions. Intended BC's are Total Pressure at Inlet and Mass flow rate at outlet. Please guide me for 0/U, 0/p, 0/nut, 0/epsilon and 0/k files.
ark704 is offline   Reply With Quote
Old   January 18, 2016, 06:52
nasir musa yakubu
Hello Ravi,
I am actually still stuck with the same problem but resolving it slowly and painfully. the best thing i think is to upload pics of your mesh, paste a copy of your log files and how you specified you boundary file, are you ale to splitMesh to create cleanse successfully?
you can start looking at these in the mean time:
http://www.cfdsupport.com/OpenFOAM-T...rt/node85.html
http://www.cfdsupport.com/OpenFOAM-T...rt/node88.html
http://www.cfdsupport.com/OpenFOAM-T...t/node101.html
http://www.cfd-online.com/Forums/ope...mplepatch.html
http://www.cfd-online.com/Forums/ope...ible-flow.html
if you do find a solution, please let me know, and i will keep you updated on my progress. i have tried the cyclic and mappedPatch and now back to trying to achieve the same result using just patch for my inlet and outlet in the boundary file but still struggling, however my simulation runs for hours before crashing due to floating point error.
best regards
Nas
closed loop, directmappedpatch, fan, flowrateinletvelocity, fluxcorrectedvelocity, mass flow rate
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
Mass flow rate Neser CFX 4 February 14, 2004 00:27
