Running OpenFOAM from Platform LSF
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 22, 2010, 11:54
Question Running OpenFOAM from Platform LSF
phinallydone is on a distinguished road
Does anyone have any experience running OF from LSF? If so, could you share an example shell script to submit the job to bsub?
Many Thanks!
phinallydone is offline   Reply With Quote
Old   June 27, 2011, 13:25
jdiorio is on a distinguished road
Posting this in response to a PM from member Linse. Sorry if this info is posted elsewhere but maybe others will find it helpful.
The key is the LSF environment variable $LSB_HOSTS which is the lists of machines assigned for your job. Create two files e.g. "parjobscript" and the "runparjob"
#script parjobscript
rm machineFile
for i in $LSB_HOSTS
do echo $i >> machineFile
done
mpirun -n 20 --hostfile machineFile simpleFoam -parallel > foam.log
#script runparjob
bsub -q limit150 -n 20 -e error.%J.log -o output.%J.log < parjobscript
The -n option in each of these files should be followed by the number of processors you want. In "runparjob" I'm submitting to the LSF scheduler using bsub, followed by the queue name (in this case limit150) and again the number of processors. The -e and -o options specify the error and log files respectively (using %J gives you the current job number).
Executing "runparjob" should assign the assigned LSF machines to OpenFOAM.
Hope this helps.
James
jdiorio is offline   Reply With Quote
Old   June 28, 2011, 09:30
Bernhard Linseisen
Linse is on a distinguished road
James, thank you very much for that information!
At the very least it points to ways how to solve the problems I have!
Linse is offline   Reply With Quote
Old   June 3, 2013, 15:10
ehk
ehsankf is on a distinguished road
Does anyone have any experience running OF from LSF with mpirun.lsf?
ehsankf is offline   Reply With Quote
Old   June 3, 2013, 15:52
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
what is LSF?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 8, 2013, 16:22
Retired Super Moderator
Bruno Santos
Greetings to all!
If you make a more specific question as to what problem you're having with LSF, it'll be easier for anyone to answer you.
Originally Posted by immortality View Post
Hi
what is LSF?
I'm not 100% certain, but I think it's this: http://en.wikipedia.org/wiki/Load_Sharing_Facility
Best regards,
Bruno
immortality likes this.
Old   July 21, 2017, 03:39
Dominic
DominicTNC is on a distinguished road
Hi all,
I am now facing the same problem. Would anyone give me some help?
With reference to James comment, I write the following script
<<<<<<<<<<<<<snappyHexMesh.sh>>>>>>>>>>>>>>
rm machineFile
for i in $LSB_HOSTS
done
mpirun -n 264 --hostfile machineFile snappyHexMesh -overwrite -parallel > foam.log
<<<<<<<<<<<<<run_snappyHexMesh.sh>>>>>>>>>>>>>>
bsub -q model_queue_high -n 264 -e error.%J.log -o output.%J.log < snappyHexMesh.sh
But it turns out that it fails to run.
Any comments are appreciated! Many Thanks!
Regards,
Dominic
DominicTNC is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
