How to calculate Pressure Difference
Old   October 28, 2010, 11:19
Default How to calculate Pressure Difference
Bernhard Lecker
Perkele is on a distinguished road
Hello Foamers,
I'm searching for a tool to calculate pressure differences between two or more eligible areas in the flow (Mainly two areas). So not only for inlet and outlet, but also for other interesting areas like a pile-up ahead of a barrier.
Has anyone a solution for me?
Thanks in advance.
Bernhard
Perkele is offline   Reply With Quote
Old   October 28, 2010, 20:24
Masashi Ohbuchi
Ohbuchi is on a distinguished road
If that area consist of boundary patch, you can use patchAverage for all area,
then calculate difference by hand. And If that area is non-patch arbitrary cut surface,
you would use paraview's filter function "Integrate Variables".
Ohbuchi is offline   Reply With Quote
Old   October 29, 2010, 09:29
Bernhard Lecker
Hi Ohbuchi,
thank you very much for your quick and helpful answer. Both ways work wonderfully!
Have a good weekend.
Bernhard
Old   October 29, 2010, 09:50
Default Calculate pressure difference
CFD user
subhkirti is on a distinguished road
Originally Posted by Ohbuchi View Post
Hi Ohbuchi and Bernhard,
Can you explain how to use 'IntegrateVariables' in paraview to calculate the pressure difference. I used it, but it does not seem to generate the correct values.
Thanks,
subhkirti is offline   Reply With Quote
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Difference in pressure drop results To all fluent users need help pls FLUENT 4 May 30, 2007 04:31
How to calculate ave dinamic pressure? Nicola CFX 1 July 20, 2006 07:01
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
