buoyant flow in a horizontal duct
Old   October 18, 2011, 19:14
Default buoyant flow in a horizontal duct
Ehsan
ehsanshams is on a distinguished road
hi,
I am trying to solve flow in a horizontal duct with inflow/outflow and constant temperature walls (top and bottom). I tried to solve it using buoyantPimpleFoam. I am not sure what I am doing wrong in my boundary conditions that give me unreasonable results.
I will appreciate any helpful comments.
my inlet BCs:
U:
inlet
type surfaceNormalFixedValue;
refValue uniform -0.01;
T:
inlet
type zeroGradient;
p:
inlet
type calculated;
value $internalField;
p_rgh:
inlet
type fixedValue;
value uniform 1e5;
ehsanshams is offline   Reply With Quote
Old   October 19, 2011, 05:05
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by ehsanshams View Post
hi,
my inlet BCs:
U:
inlet
T:
inlet
type zeroGradient;
p:
inlet
type calculated;
p_rgh:
inlet
type fixedValue;
value uniform 1e5;
For you temperature you should define an inlet temperature, you do have an temperature of the flow that comes in, don't you?
so for T inlet BC, I would suggest
inlet
type fixedValue;
value uniform 293; // in case it is room temperature,
~roman
romant is offline   Reply With Quote
Old   October 19, 2011, 11:57
Ehsan
Roman,
Thank you for reply.
I had already tested it with defined temperature and it would not help. The problem is I get reverse flow at inlet and also very large pressure inside the domain.
Now, I define p_rgh, T, and U as a constant value (at inlet), and still get a wrong answer.
Does anyone know what excatly the surfaceNormalFixedValue does at the inlet?
How can I learn the way openfoam handles boundary conditions?
Thank you,
Old   October 20, 2011, 02:53
Default inlet conditions and outlet conditions
romant's Avatar
Roman Thiele
Inlet conditions
U:
inlet
type fixedValue;
value uniform (1 0 0);
p_rgh:
inlet
type buoyantPressure;
rho rhok;
value uniform 1e5;
T:
inlet
type fixedValue;
value uniform 293;
outlet conditions
U:
outlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
p_rgh:
type fixedValue;
rho rhok;
value uniform 1e5;
T:
outlet
type zeroGradient;
~roman
Old   October 20, 2011, 14:19
Ehsan
thanks Roman,
I tried this and worked well:
p_rgh:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 1e5;
U:
inlet
outlet
type zeroGradient;
what does rho rhok; mean?
does it matter if use fixedValue instead of buoyantPressure for p_rgh at outlet?
thank you
Old   October 21, 2011, 02:03
romant's Avatar
Roman Thiele
thanks Roman,
buoyantPressure for p_rgh is also a zeroGradient boundary condition, but especially designed for buoyantFlows.
The description from OF for buoyantPressure is
Description
    Set the pressure gradient boundary condition appropriately for buoyant flow.
    If the variable name is "pd" assume it is p - rho*g.h and set the gradient
    appropriately.  Otherwise assume the variable is the static pressure.
~roman
mass flow through a duct wisemo FLUENT 0 July 8, 2011 14:25
Turbulent Flow in a Square Duct using LES Hock Ming FLUENT 0 February 7, 2009 20:25
Flow direction in Buoyant flow Nav CFX 4 June 30, 2008 00:50
Modeling Turbulent Horizontal Buoyant Jets Jack Travis Main CFD Forum 2 September 11, 2006 06:36
in flow and out flow in a short duct jane Main CFD Forum 0 March 27, 2004 23:08
