OpenFOAM cluster
Old   November 15, 2011, 17:53
Default OpenFOAM cluster
Robert
lordvon is on a distinguished road
I am trying to run 1.5-dev ggi in an Ubuntu lan cluster by ethernet switch.
I have been trying to follow these instructions posted on another thread:
1 - In version 1.7.1, put the line . / Opt/openfoam171/etc/bashrc AS FIRST LINE in the files sudo gedit /etc/profile , sudo gedit ~/.Profile and gedit ~/.Bashrc. In all machines in the network you will use.
2- In file machines (which can be created in the tutorial) put the machine name followed by how many processors are used on this machine.
Example
ubuntu1
ubuntu2 cpu = 2
3 - Give decomposePar in all machines.
4- Type mpirun --hostfiles machines -np <number of prpcessos> <solver name> - parallel
But I can't get it to work. I replaced the ". /opt/..." with "/usr/lib/OpenFOAM-1.5-dev/etc/bashrc" for 1.5-dev.
The error is:
mpirun was unable to launch the specified application as it could not find an executable:
Executable: --hostfiles
Node: myName-desktop
while attempting to start process rank 0.
Has anybody successfully run openfoam 1.5-dev successfully in a cluster with similar instructions?
lordvon is offline   Reply With Quote
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com Markus Schmidberger OpenFOAM Announcements from Other Sources 0 July 26, 2011 08:18
Parallel cluster solving with OpenFoam? P2P Cluster? hornig OpenFOAM Programming & Development 8 December 5, 2010 16:06
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
How to install the OpenFoam in the cluster. Please help me! flying OpenFOAM Installation 6 November 27, 2009 03:00
