February 29, 2012, 12:20 |
Code for Nusselt number
Goutam Saha
I have used the following code created by Johan Magnusson. It creates the tool NusseltCalc. Only problem is, when I run NusseltCalc then I got the error:
Command not found. Could you please help me? I am adding the code as an attachment. |
March 1, 2012, 12:18 |
Markus Rehm
have you correctly compiled the tool? You need to do a "wmake", see the Wiki for more information on that topic. Markus |
March 1, 2012, 12:28 |
Goutam Saha
Dear Members,
This is the code for local Nusselt number: volScalarField wall_localNusselt ( IOobject ( "wall_localNusselt", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("wall_localNusselt ",dimless,0.0) ); forAll(wall_localNusselt.boundaryField(),patchi) { wall_localNusselt.boundaryField()[patchi] = length*patchHeatFlux[patchi]/((T_hot-T_ini)*k); } wall_localNusselt.write(); } I want to write a code for Average Nusselt Number. Last edited by Goutam; March 3, 2012 at 08:32. |
March 1, 2012, 12:48 |
Solved !!!
Goutam Saha
The code was correct. NusseltCalc is working now.
March 1, 2012, 13:07 |
Problem !!!
Goutam Saha
How to calculate average Nusselt number?
March 2, 2012, 03:21 |
Markus Rehm
DearGoutam,
I have not used the code but it would be helpful to see the error message. Markus |
March 2, 2012, 04:35 |
Goutam Saha
Looking for a response?
March 5, 2012, 07:10 |
Markus Rehm
Hello Goutam,
please be a bit more precise. As far as I understand, the code you posted above calculates the patch-averaged Nusselt number. Because patchHeatFlux should be the heat flux over the patch in [W/m2], right? Markus |
March 5, 2012, 07:16 |
Goutam Saha
Dear Markus,
This code will calculate heat flux and Local Nusselt NUmber at each patch. I am using this code and its working properly. If you want to calculate average Nusselt number, then just write in the terminal window: patchAverage wall_localNusselt your_patch_name You will get your average Nusselt number. Cheers !!! Last edited by Goutam; March 7, 2012 at 05:29. |
June 22, 2014, 05:47 |
#10 | |
shiv
I have used the same code and terminal command for calculating the nusselt number for a case of fin tube heat exchanger using chtMultiRegionSimpleFoam solver but i am getting: Code:
Create time Create mesh for time = 0 Time = 0 No field NusseltNumber Time = 1600 No field NusseltNumber Time = 1700 No field NusseltNumber Time = 1800 No field NusseltNumber Time = 1900 No field NusseltNumber Time = 2000 No field NusseltNumber End |
June 22, 2014, 05:59 |
#11 |
shiv
From what i understand from code, this is not a post processing utility rather a runtime utility and i need to create a volumetric scalar field NusseltNumber for it to work. Plz let me know your views. |
June 23, 2014, 06:05 |
#12 | |
Goutam Saha
October 24, 2014, 15:58 |
Nusseltcalc.C
#13 |
Lorenzo Gomes
Rep Power: 12 |
Hello there,
I'm trying to compile the tool but I keep receiving this error: Code:
NusseltCalc.C: In function 'int main(int, char**)': NusseltCalc.C:61:38: error: missing template arguments before '->' token Any ideas why? Thanks. |
October 24, 2014, 16:29 |
#14 |
RASModel is class name, did you mean turbulence->alphaEff()? (also this method is available only for compressible turbulence models, in case of incompressible model you have to calculate is as nu/Pr + nut/Prt) |
October 27, 2014, 11:52 |
#15 |
Lorenzo Gomes
Rep Power: 12 |
Thanks for the quickly reply. That killed that error but now I can't find a way to link the libraries I need. The error is this:
/usr/bin/ld: cannot find -lcompressibleTurbulenceModel /usr/bin/ld: cannot find -lcompressibleRASModels /usr/bin/ld: cannot find -lcompressibleLESModels /usr/bin/ld: cannot find -lLESdeltas /usr/bin/ld: cannot find -lreactionThermophysicalModels /usr/bin/ld: cannot find -lfiniteVolume /usr/bin/ld: cannot find -lgenericPatchFields /usr/bin/ld: cannot find -lspecie /usr/bin/ld: cannot find -lfluidThermophysicalModels /usr/bin/ld: cannot find -lsolidThermo My options file in /Make dir is this: Code:
EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -lcompressibleTurbulenceModel \ -lcompressibleRASModels \ -lcompressibleLESModels \ -lLESdeltas \ -lreactionThermophysicalModels \ -lfiniteVolume \ -lgenericPatchFields \ -lspecie \ -lfluidThermophysicalModels \ -lsolidThermo |
October 27, 2014, 12:41 |
#16 |
it looks much like you've forgotten to set up environment variables. |
October 27, 2014, 12:49 |
#17 |
Lorenzo Gomes
Rep Power: 12 |
I´m kind of new at this. How can I do that?
February 8, 2015, 15:13 |
#18 |
james wilson
Rep Power: 11 |
basically we can calculate local nusselt numbers over a patch as we've seen in the discussion above. To get an average nusselt number, you must do some area weighting in the case of a non uniform mesh. Below, you calculate the local nusselt number at each face on heatedPatchID and multiply by the faces area. You must also calculate the total patch area. Once each local nusselt number is weighted by its own area of its face on the boundary, you divide the entire sum of area weighted nusselt numbers by the total area. This results in an averaged nusselt number.
Take a uniform mesh for example: e.g. (A1*Nu1 +A2*Nu2 +... An*Nun)/Atotal = NUM/DEN where A1 is the face area of face 1 on heatedPatchID and Atotal is the entire patch area and if A1 = A2 = An (uniform mesh), then A1 = Atotal/n = A2 = .. = An resulting in Atotal(Nu1 + Nu2 + ... +Nun)/(Atotal*n) = (Nu1 + Nu2 + ... +Nun)/n), which quite simply in a basic average of n components. This is how we integrate numerically along a dimension in most cases where we divide the area weighted sum by the total area of that boundary of interest whether it be length, area or volume. Code:
label heatedPatchID = mesh.boundaryMesh().findPatchID("heatedBoundaryName"); const polyPatch& cPatch = mesh.boundaryMesh()[heatedPatchID]; scalar patchArea = 0.0; scalar eps = 1e-99; //avoid divide by zero forAll(cPatch, facei) //Cycle through all of the boundary faces of heatedPatchID to find total patch area { localArea = magSf.boundaryField()[heatedPatchID][facei]; patchArea += localArea; //building DEN } // i suppose scalar patchArea = sum(magSf.boundaryField()[heatedPatchID]); //would suffice scalar averageNusseltNumber = sum(T.boundaryField()[heatedPatchID].snGrad() * magSf.boundaryField()[heatedPatchID])/(T.boundaryField()[heatedPatchID]-Tsat.value()+eps)/(patchArea + eps); //calculating NUM/DEN Any comments are welcome. James |
December 16, 2016, 10:21 |
#19 |
Djamila
Rep Power: 9 |
February 7, 2017, 11:30 |
changes for OF 4.1
#20 |
If someone wants to implement the code of Johan Magnusson (shown in post #3) in OpenFOAM 4.1, one only need to change
forAll(wall_localNusselt.boundaryField(),patchi { wall_localNusselt.boundaryField()[patchi] = length* patchHeatFlux[patchi]/((T_hot-T_ini)*k); } Code:
forAll(wall_localNusselt.boundaryFieldRef(),patchi { wall_localNusselt.boundaryFieldRef()[patchi] = length* patchHeatFlux[patchi]/((T_hot-T_ini)*k); } A detailed description of the implementation is given in his report ("conjugateHeatFoam with explanational tutorial together with a buoyancy driven flow tutorial and a convective conductive tutorial") |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
State of the art in CFD technology | Juan Carlos GARCIA SALAS | Main CFD Forum | 39 | November 1, 1999 14:34 |
