Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Pulsating Flow in a Circular Pipe
Old   November 13, 2014, 01:57
Default Pulsating Flow in a Circular Pipe
Shivam Sinha is on a distinguished road
I tried simulating the velocity profile for pulsating flow in a cylindrical pipe.
But my results don't quite match with the results published in the paper "Development Length of sinusoidally pulsating laminar pipe flows" by Franz Durst, even though I have used the same flow conditions.
I've attached my OpenFOAM code and some graphs comparing my results with those published in the paper. (In the graph, the brown lines indicate the fully developed velocity profile from my simulation results while the black dots represent the results from the paper)
Probably, there is something wrong with the finite volume schemes that I have used. Please have a look at the code I have attached.
Shivam Sinha is offline   Reply With Quote
Old   November 14, 2014, 16:28
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. Well, now quite good mesh for 3D simulation.
2. Do you really need 3D simulation? It's 2D axisymmetric.
3. 20x350 is not 80x400. Well, at least you've use the same scheme.
(i.e. try going with 2D axisymmetric variant, it's much easier)
4. Are you sure your dt is fine enough?
alexeym is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Reproduce Nusselt number correlations for forced turbulent flow inside circular pipe michujo Main CFD Forum 2 March 14, 2014 08:22
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
flow in circular pipe Jackie Main CFD Forum 1 February 18, 2003 12:58
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
