Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Is there any test case to test turbulence modelling for two phase flow?
Like Tree2Likes
  • 2 Post By BlnPhoenix
Old   August 22, 2019, 05:28
Default Is there any test case to test turbulence modelling for two phase flow?
krishna kant
kk415 is on a distinguished road
Hello All
I am looking for a test case for to verify turbulence model in a two phase flow system. I have spent hours for the same. Can anyone suggest one ?
kk415 is offline   Reply With Quote
Old   October 10, 2019, 07:55
BlnPhoenix is on a distinguished road
Are you talking about a test case that uses bubble induced turbulence model that is programmed into an Euler-Euler solver? I'm not aware of any..
There is the kOmegaSSTSato for example that you can try to use for experimental data that maybe can be found online..
wanggl and kk415 like this.
BlnPhoenix is offline   Reply With Quote
Old   October 11, 2019, 04:34
krishna kant
Hello
Thanks for the reply.
My aim is to solve atomization problems in two phase flow. Since turbulence instability of the liquid jet plays a major role in the breakup. I am looking for some standard test case for analyzing turbulence instability of my solver.
One way is to validate it with experimental data available for jet break up. But since it is going to be a validation for the solver so I am looking for a standard numerical test case for analyzing turbulence instability in two phase system.
And yes the solver is Euler-Euler solver similar to s-CLSVOFFoam.
[OpenFOAM.com] Installing on Ubuntu 18.04 samiam1000 OpenFOAM Installation 11 April 27, 2020 00:01
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 bjdarrer OpenFOAM Installation 2 April 20, 2020 13:50
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background pchoopanya Main CFD Forum 4 May 10, 2018 11:05
2 phase flow validation on this case. Ash Kot Fluent Multiphase 0 May 31, 2017 03:11
The turbulent swirling flow test case - Dellenback dogan Main CFD Forum 0 February 27, 2013 08:10
