how to know when mesh is sufficiently refined? |
Josh McCraney
Rep Power: 10 ![]() |
Hi FOAMers!
I'm running a simulation in interFoam, and it takes a long time to run. The simulation is simply liquid being drained from a container in zero gravity, and the tank is a little smaller than a mailbox (160 mm in length). Before running the simulation I would like to know if my mesh is sufficiently refined. How would you do this? |
Herpes Free Engineer
Rep Power: 13 ![]() |
That literally requires a book to answer. Depends on gazillion of parameters (e.g. RANS or LES?) I would isolate and minimise this question.
In any case, have a review on `grid quality metrics` (e.g. Richardson extrapolation, `grid convergence index` etc.)
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Josh McCraney
I'm not using RANS or LES: I'm using a non-turbulence model. Does this help?
Rep Power: 7 ![]() |
you could make grid independence test to see if the mesh is refined enough.
Josh McCraney
Hi
- Please do google the following keywords: 'grid indepence test', 'grid independency', 'Richardson extrapolation' to get the sources. - In the nutshell, you start with a set of settings and mesh of a spatial-temporal resolution, select a flow quantity, and refine mesh and monitor the flow quantity to see whether increasing spatial or temporal resolution changes the outcome. If no considerable change occurs on the flow quantity by increasing those resolutions, you do then assume that your mesh or setup is grid independent. - Do changes in isolation, and monitor changes in isolation. Dont change every possible settings at the same time. Hope makes sense. (was writing on the phone, thus bad quality answer in terms of style)
Display Modes | |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
