Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Stokes Flow arround a single sphere
Old   November 8, 2021, 09:38
Default Stokes Flow arround a single sphere
Niko
NFisc is on a distinguished road
Dear Foamers,
I am currently simulating Stokes Flow arround a single sphere and try to compare the results to the analytical solution.
Analytical Solution/Theory: We have incompressible flow at very low Reynolds numbers (< 1) in a cube geometry with a single sphere in the middle with periodic BC at all cube sides and noSlip on the sphere's boundary (Image attached). A force is added to the N-S-Eqn to enforce fluid flow solved with a steady-state solver (simpleFoam):
\bf{v}\cdot \nabla\bf{v}= -\nabla p - \bf{S}
Since the flow is at very slow flow, one can neglect the left-hand-side and the pressure drop should be equal to the added source term:
\nabla p \approx \bf{S}
We can compare the results with the analytical solution of Sangani (1982, "Slow Flow Through A Periodic Array of Spheres") by calculating the incompressible pressure and viscous force, which are used to calculate the non-dim drag K for spheres with different diameter via:
K = \frac{F_{D}}{6\pi \mu U r}
with F_{D}= F_{pressure}+F_{viscous} which we will get from postProcess -func forcesIncompressible, U is the darcy velocity and r the radius of the sphere, \mu the viscosity.
With this we can calculate the non-dim K which is in very good agreement with the analytical solution (Image attached).
So here is the problem: Even though the K values are correct, the calculated pressure drop is not even close to the added source term as mentioned above in the N-S-Eqn. Further, the pressure field does not look correct as it should be a linear gradient through the domain, but this is not what it looks like (Image attached).
Here is what I tried (next to refine the mesh): mappedOutlet BC for the inlet velocity, with zeroGradient velocity at the outlet and set a fixed pressure gradient between inlet (uniform 1E-3) and outlet (uniform 0). With this I get the correct pressure drop gradient and pressure field but the non-dim K is completely off (calculated again with postProcess -forcesIncompressible).
This leads to my dilemma: Either a correct non-dim K or a correct pressure gradient....
Any explanation or help is appreciated. Am I missing something regarding the BC or the theory?
NFisc is offline   Reply With Quote
Old   March 12, 2022, 01:07
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Cyclic b.c. arise problems. I recommend working first with an ordinary inlet and outlet first.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Water Sphere reacting to flow of air modelling Jacee FLUENT 0 May 25, 2018 09:29
Symmetry Boundary Condition for Flow Past a sphere Qkarl Main CFD Forum 14 March 6, 2018 03:32
Flow in canal with solid sphere obstacle Gandel FLUENT 0 May 3, 2017 04:59
superSonic Flow around sphere prapanj OpenFOAM Running, Solving & CFD 0 March 17, 2009 01:20
Stokes Flow george FLUENT 3 July 30, 2001 05:33
