April 23, 2012, 20:09 |
how to mesh a cylinder fixed in water tank
llh
hi,
I would to add a cylinder(fixed) in the middle of a wave tank, how to do the mesh generation? I learned from tutorial "flow around a cylinder" http://www.foamcfd.org/Nabla/guides/...Guidese12.html and divided the tank into 20 blocks. The first problem is about "inequality of cells number between neighbour blocks" I dont quite understand about how to set the red part of each block, the order or the numbers after it: hex (4 9 10 5 23 28 29 24) (100 20 50) simpleGrading (1 1 1) The second problem is after mesh generation (I just set all the numbers of cells in each direction equals the same) I use waveFOAM to generate wave and finally I got floating point exception issue, i am not sure if it is caused by wrong mesh generation, is there any way to solve it? Regards, Vricc |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 05:55 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
