Best Book to Accompany OpenFOAM
Old   May 22, 2012, 16:46
Default Best Book to Accompany OpenFOAM
Matthew Denno
mgdenno is on a distinguished road
Hello OF Users,
I have been using OF for a little while now and am looking to learn more about CFD theory and dive into the coding of the applications. I have been watching the lectures and doing the exercises for ME702 class at Boston University
http://www.cfd-online.com/Forums/mai...-itunes-u.html
And I am now looking for a good text book to purchase. I have read through the list of books and the comments on the cfd-online website and have sort of narrowed it down to the following three:
H.K. Versteeg and W. Malalasekera
John David Anderson
Joel H. Ferziger and Milovan Peric
My question is which book would go best with OF? It doesn't need to be limited to the three here, I was just using them as a starting point.
Thanks for your thoughts,
MD
mgdenno is offline   Reply With Quote
Old   May 22, 2012, 22:33
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
FOAM has the nomenclature similar to Ferziger. Versteeg is good for understanding. I don't know the second one.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 22, 2012, 22:44
Matthew Denno
Santiago,
Thank you for your comments. That is exactly what I wanted to know.
Matt
Old   May 23, 2012, 11:45
Vesselin Krastev
vkrastev is on a distinguished road
Prof. Jasak's PhD Thesis (which is available online for free) would be also a good reading to better understand how OpenFOAM works (there you can find descriptions of most of the numerics and discretization practices used in OF).
Regards
V.
vkrastev is offline   Reply With Quote
Old   May 24, 2012, 03:02
Elvis
elvis will become famous soon enough
maybe it is old stuff for you.
But I think "MSc/PhD course in CFD with OpenSource software" by Håkan Nilsson from Chalmers http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2010/ http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2011
and the Openfoam Workshop trainings are worth mentioning.
Prof. Jasak PHD thesis & more can be found http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/
elvis is offline   Reply With Quote
Old   May 25, 2012, 21:35
Matthew Denno
elvis, vkrastev,
Thank you for your suggestions, I will check them both out.
MD
Book recommendations for OpenFOAM? Nontagonist OpenFOAM 2 October 17, 2011 09:13
OpenFOAM (Linux) in a MS-HPC-Cloud fossy OpenFOAM 6 September 23, 2010 11:48
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
Getting OpenFOAM to coexist with an existing JAVA VM nik777 OpenFOAM Installation 5 February 22, 2007 07:21
