Individually access of a dictonary for any decomposed processor - Parallel computing
Old   October 1, 2012, 05:40
Default Individually access of a dictonary for any decomposed processor - Parallel computing
Peter_600 is on a distinguished road
I would like to run a case in parallel and to execute specific tasks on different processors.
To achieve this I like to control the behavior within a script which is stored, let s say inside the constant folder for any particular processor?
Any ideas?
Peter
Peter_600 is offline   Reply With Quote
Old   October 1, 2012, 08:32
Bernhard
Bernhard is on a distinguished road
What should this script do exactly? Is it to be called every iteration, time step? Maybe there is a different way to achieve what you want...
Bernhard is offline   Reply With Quote
Old   October 2, 2012, 10:40
Actually I want to use the attachDetach topochanger in parallel.
I ve figured out that it crashes because some processors don t contain the physical attach/detach faces. Thus, I would like to skip the attach/detach function for those processors.
Therefore, I like to have in any processor folder a file which allows to switch on or off the attach/detach function, assuming weither there is a detach/attach boundary or not.
I know I have to change the source code, but I want to give a try.
I can create within my solver moveDynamicMesh in the beginning a file like
// Read dictionary for attach Detach Switch
Pout << "Read Dictionary attachDetachSwitch" << nl;
IOdictionary attachDetachSwitch
IOobject
"attachDetachSwitch",
time().constant(),
//mesh,
*this,
IOobject::MUST_READ,
IOobject::NO_WRITE
word attachSwitchState;
attachSwitchState = word(attachDetachSwitch.lookup("attachDetachSwitch "));
Pout << "Attach Detach State: " << attachSwitchState << nl;
Now I would like to use the object attachSwitchState in different classes. Like in
attachDetachFvMeshAttach.C
attachDetach.C.
to perform some if statements.
I don t know how I can pass this object which contain either" false or true " to any of this classes. Is it possible? Or am I totally wrong ?
Cheers Peter
Btw, I am using 1.6-ext
