Help needed in specifying BC for superconic intake simulation |
October 25, 2012, 07:21 |
KGN
I am trying to simulate an axi-symmetric ramjet intake. Plz find the geometry & BC in the attached image. I am specifying
i am using rhoCentralFoam solver. I ran the simulation for few time steps and then calculated the "Total pressure" using "ptot" utility at the inlet, but its not matching with the inlet condition. But the Mach number is matching. How? i.e. @ Inlet specified static P = 28,562 Pa static T = 153.81 K velocity = 542 m/s (The above values are calculated using isentropic relations) calculated Total Pressure = 123,343 Pa, but actual value is 296,000 Pa. But the Mach number is matching 2.18 Regards KGN |
October 25, 2012, 12:13 |
Kyle Mooney
Is it possible that specifying both a pressure drop and velocity inlet boundary condition is over specifying the problem? Maybe try just the pressure drop and see what U field evolves to meet it. I'm no expert in compressible flows so I may be way off on this.
October 25, 2012, 16:08 |
Chris Sideroff
Rep Power: 22 |
For supersonic flows you specify all values at inlet and no values at outlet. You can refer to one of the many compressible flow CFD books that show this to be true by examining the characteristic wave propagation.
For subsonic flows you specify all values but one and at the outlet only one value. This is why it is quite common for subsonic flows to specify all the velocity components (or velocity magnitude and direction, which is the same thing) but not pressure at the inlet and only pressure at the outlet. -Chris |
October 25, 2012, 23:45 |
KGN
I figured out the problem.
The "ptot" utility is using Bernoulli's equation to calculate the total pressure. So this is for incompressible flows. I used ParaView calculator to calculate the total pressure and the value matched |
Turbulent simulation of Ramjet engine intake | mecbe2002 | OpenFOAM Running, Solving & CFD | 1 | May 1, 2016 15:02 |
Simulation time vs. Simulation Cell Count | chrisoturner | Main CFD Forum | 7 | September 8, 2012 17:46 |
Intake Flow Simulation Accuracy | atlantis83 | FLUENT | 0 | April 25, 2010 05:18 |
Blunt body aerodynamics simulation cases needed | David | FLUENT | 0 | June 1, 2003 11:40 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
