interFoam and Continuous-Species-Transfer (CST) method
Old   May 4, 2011, 05:22
Default interFoam and Continuous-Species-Transfer (CST) method
Kelvin Loh
kel85uk is on a distinguished road
Hi all,
I need some help in determining if I am on the right track to implement the jump conditions for species concentration across the air-water interface for a bubble. The base solver I am using is interFoam without AMR/MRF functions. I thought of keeping it simple first before adding more functionality.
  forAll(Diffusion_cell,cID)
        Diffusion_cell[cID]=D_spec_liq.value()*D_spec_gas.value()/(D_spec_gas.value()*alpha1[cID] + D_spec_liq.value()*(1.0 - alpha1[cID]));
        turbulence->correct();
    forAll(gamma_diff,cIID)
        gamma_diff[cIID] = -Diffusion_cell[cIID]*(1-He)*C[cIID]/(alpha1[cIID] + He*(1.0 - alpha1[cIID]));
        solve(fvm::ddt(C) + fvc::div(phi,C) - fvc::laplacian(Diffusion_cell,C) == fvc::laplacian(gamma_diff,alpha1));
The Diffusion_cell, and gamma_diff variables are of the volScalarField type. I tried a simple cube test case with no flow velocity imposed, but the run was unsuccessful. Also, I noticed that the value of grad(alpha1) is not 0 inside the phases, which cannot be correct.
The equations are based on one of the references (Haroun et al, 2008) in Holger Marschall's 5th OpenFOAM workshop abstract of the same case.
http://www.tfd.chalmers.se/~hani/OFW5/timeSchedule_workshop_online-filer/Abstract_final/HolgerMarschallAbstractOFW5.pdf
Any hints/help whatsoever is much appreciated.
Thank you.
Regards,
kel85uk
kel85uk is offline   Reply With Quote
Old   May 10, 2011, 03:59
tiantian
cqworm is on a distinguished road
I am doing the same work.
If possible you could email me for more convenient exchange ideas.
Looking for more professional ones posting here...
cqworm is offline   Reply With Quote
Old   December 22, 2012, 19:05
Default Jump conditions in interFoam
Hanniel Freitas
hfsf is on a distinguished road
Guys, i've strumbled upon the same question. Recently I've got some help in a post that could be very useful: http://www.cfd-online.com/Forums/openfoam/109477-equilibrium-thru-interface.html
In that post the user nimasan described and alternative approach to use the jump conditions within the VOF approach, with some interesting reference background.
Best,
hfsf
hfsf is offline   Reply With Quote
