Internal Flow with Heat Transfer
Like Tree1Likes
  • 1 Post By chegdan
Old   January 14, 2013, 12:17
Default Internal Flow with Heat Transfer
plucas's Avatar
Anonymous
plucas is on a distinguished road
I have never used OpenFoam for internal flow or heat transfer. I have always used it for automotive external aerodynamics. That being said, I am looking to expand my knowledge for a personal project I am going to be doing.
I am looking to model my design using CAD (ProE) and mesh using snappyHexMesh. It would be internal flow of water/glycol through copper/aluminum tubing in a coil under ground. I would like to run a steady state incompressible analysis that calculates heat transfer. The flow would be turbulent, and I was think a k-omega sst turbulence model (is this best?).
So my questions are...
1. Any good tutorials to follow to get the basic idea? I have searched but I am failing to find anything.
2. What solver should I use since heat transfer will be implemented?
3. How should I setup the blockMesh and snappyHexMesh is this situation?
4. Is my assumption of using a k-omega sst turbulence model correct? This is what I have found on the little information I was able to locate.
The picture of the real thing I am trying to simulate is below.
plucas is offline   Reply With Quote
Old   January 15, 2013, 10:31
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Plucas,
Let me try to answer a few of these
1. There are fluid solid problems in the heat transfer folder in tutorials.
2. If you want to capture the pipe heating and local heating of the soil outside your pipe, try chtMultiRegionSimpleFoam. However, you may be able to do this more simply with a flux at the wall and then use simpleFoam with a temperature field added (http://www.cfd-online.com/Forums/ope...tml#post280210). However, since the pipes may be overlapping and touching...you may be stuck with the more complicated and time consuming solvers.
3. Depends on the case, but you want nice refined mesh at the wall and through the boundary layer in the pipe.
4. You can try multiple turbulence models, but this one is a good one.
mizzou likes this.
chegdan is offline   Reply With Quote
Old   January 18, 2013, 11:47
plucas's Avatar
Anonymous
Thanks for the response
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
heat transfer with laminar flow David_010 OpenFOAM 10 November 16, 2012 16:05
axial flow around a cylinder -heat transfer model? Ralf Schmidt FLUENT 0 March 21, 2006 03:29
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 14:20
