How to generate ".stl" file for OpenFOAM
Like Tree2Likes
  • 1 Post By kilroy
  • 1 Post By mturcios777
Old   April 18, 2013, 09:50
Default How to generate ".stl" file for OpenFOAM
kilroy's Avatar
kilroy is on a distinguished road
For my analysis I need a ".stl" file of a shape, but I don't know how to generate that.
The mathematical equation of my shape is below:
y=B/L[1-(2x/L)^2][1-(z/D)^2]
where L=4, B=0.4 and D=0.25
The shape is basically a canoe.
What is the easiest way to get a shape like that?
Thanks,
ordinary likes this.
kilroy is offline   Reply With Quote
Old   April 18, 2013, 13:19
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
You might be able to make it using sources in paraView; they have spheres as a source, which can then be deformed and clipped accoring to your needs.
Once you have the geometry you want, then run the "Extract Surface" filter, and save the data as an STL.
mturcios777 is offline   Reply With Quote
Old   April 18, 2013, 13:38
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
I would recommend FreeCAD. You can program shapes using Python, and it is Open Source. Another option is OpenSCAD, which is also Open source.
You can also generate your shapes with Soldiworks or even MATLAB.
JR22 is offline   Reply With Quote
Old   April 19, 2013, 02:25
RDG
onyir is on a distinguished road
You could also try SALOME. I think you can make geometry from mathematical equations, apart from having powerful python scripting capabilities.
onyir is offline   Reply With Quote
Old   April 19, 2013, 02:45
Eelco van Vliet
eelcovv is on a distinguished road
A nice alternative to openscad is openJscad :
http://joostn.github.io/OpenJsCad/index.html
It is based on java and runs in your webbrowser wit webGL. The programminglanguage is more powerful than openscad though. Some nice tutorials can be found
Cheers
Eelco
eelcovv is offline   Reply With Quote
Old   April 19, 2013, 17:32
Retired Super Moderator
Bruno Santos
Greetings to all!
A couple more to add to the list:
Best regards,
Bruno
Old   April 23, 2013, 09:45
kilroy's Avatar
Today I have learned that my university have licenses for the Creo software. I think I can use that for generating STL files too.
Thank you very much for your answers,
[swak4Foam] Error installing swak4Foam Hisham OpenFOAM Community Contributions 182 February 8, 2024 10:36
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
